1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. allanch
    Cupcake Sep 27, 2018
    allanch , Sep 27, 2018 :
    So just to clarify, if I am on open beta build, I have to downgrade before I can download and install the stable build of android P?
  2. vele060
    Eclair Sep 27, 2018
    vele060 , Sep 27, 2018 :
    you can download the pie file and upgrade but i recomend full format
  3. simrangill1551
    Donut Sep 27, 2018
  4. Wes80
    Donut Sep 27, 2018
    Wes80 , Sep 27, 2018 :
    I agree. I work in a factory and my hands are covered with greese 80% of the time and it's a hell of a lot easier to look at my phone then grab a shop rag just to pick my phone up to see the time. it's very inconvenient.
  5. Kytharsis
    Marshmallow Sep 27, 2018
    Kytharsis , Sep 27, 2018 :
    Yes, you have to downgrade to return to the stable branch. Your data will be deleted in the process so I recommend backing up your important items.
    Yeah, no.
  6. vele060
    Eclair Sep 27, 2018
    the file is in xda forums and you dont need to do a reset but the old data from beta can give you problems
  7. Kytharsis
    Which file?
  8. abukhulood
    Froyo Sep 27, 2018
  9. gurinderjeet091
  10. TheHoneyBoy
    TheHoneyBoy , Sep 27, 2018 :
    hmmm...it was on the early stage of android pie...i was bit skeptical downloading the upgrade but accepted it since it will be --soon-- be stable and we just have to be patient since oneplus have generally a clean UI. Like some bugs (does not really matter to me) like am using gestures, and while using back,(recent apps) while scrolling, you will notice other apps are in similar fashion, while other one was enlarged)...like that.
    Best suggestion for now is, let us wait for the complete version of pie (expect it to be fully stabilized on the arrival of 6T), and if not that contented with present version of pie, well stick to oreo for a whille.[e]1f601[/e]
  11. Kytharsis
    That's because people kept abusing it.
  12. Drifting Shade
    Donut Sep 27, 2018
    Texasaggie1 likes this.
  13. urmilk
    urmilk , Sep 27, 2018 :
    My Fitbit does not connect via Bluetooth. I keep getting error... screenshot below. Have not run into any issues connecting Bluetooth to my car or other devices yet.
    [Update]: Used Forget device option in Bluetooth and reconnected my Fitbit and it worked. Looks like the solution works.
    vanyaindigo likes this.
  14. ulats07
    Eclair Sep 27, 2018
    ulats07 , Sep 27, 2018 :
    i have an issue with grab driver app with official 9.0,the app keep shutting down,i do not have an issue with open beta 3,is it possible to downgrade from official to beta rom with dirty flash without
    clearing all the data.
  15. vele060
    Eclair Sep 27, 2018
    i cant post it but look for it. and if you learn some tricks you can do magic repacking.
  16. vele060
    Eclair Sep 27, 2018
    erase the data from tha app
    ulats07 likes this.
  17. ulats07
    Eclair Sep 27, 2018
    done that,ive have been in touch with grab cs since the issue occur,still the same
    TheHoneyBoy likes this.
  18. seanj18
    seanj18 , Sep 27, 2018 :
    I just got the update no more than two hours ago, and my wireless data was working great pre update. Since the update though, my phone signal entirely has been on the fritz. My data is on, I have an up-to-date service plan. Any ideas?
  19. vele060
    Eclair Sep 27, 2018
    reset network settings and restart
  20. L1521868764494
    L1521868764494 , Sep 27, 2018 :
    Hi could any one help me i have bhought my new one plus 6 red version still i did not received Android pie Update
    how could I sort this issue
