1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. vele060
    Eclair Sep 27, 2018
    vele060 , Sep 27, 2018 :
    go to apps and look for the app erase cache and data for the app uninstalling the app will not erase that data
    ulats07 likes this.
  2. ulats07
    Eclair Sep 27, 2018
    ulats07 , Sep 27, 2018 :
    download oxygen updater via play store
    TheHoneyBoy likes this.
  3. ulats07
    Eclair Sep 27, 2018
    still no go
  4. seanj18
    Cupcake Sep 27, 2018
    seanj18 , Sep 27, 2018 :
    Which network settings? Because wifi works fine, it's literally just moblie data.
  5. Texasaggie1
    US Brand Ambassador Sep 27, 2018
    Texasaggie1 , Sep 27, 2018 :
    the always on display is something I really miss in pie also.
    my phone is rooted and so I used the work around to bring back the always on display while I was on nougat. everybody needs to know that I did not notice any battery loss when I had it on, or battery savings when I had it off. I know OnePlus has their reasons but I really wish they would leave the whole battery part up to me. I would still want it even if it took away 1/3 of my battery every day.
    anyway, OnePlus please consider this an upvote and please get us back the always on display as soon as possible. Thank you!
    simrangill1551 and Wes80 like this.
  6. Stanley08
    Gingerbread Sep 27, 2018
    Stanley08 , Sep 27, 2018 :
    Even at the risk of sounding like a crazy noob.... I will ask.
    Open Beta 3 and Official Pie.
    Which one do you guys like better?
  7. ulats07
    Eclair Sep 27, 2018
    open beta 3 work better for me
  8. G_Murukonda_Vinayak_gAbv
    Froyo Sep 27, 2018
    G_Murukonda_Vinayak_gAbv , Sep 27, 2018 :
    after the update battery of my bluetooth is not showing up i have to drag down the tools bar to check the battery capacity. this happened to phones battery level in previosu versions which was later fixed with and update. hope it happens again.
  9. surajms89
    Donut Sep 27, 2018
  10. Deactivated User
    Sep 27, 2018
    ulats07 likes this.
  11. ulats07
    Eclair Sep 27, 2018
    done that,they not very technical savvy
    its working when i was on beta 3 android pie,thats why i wondering why its not working on pie official
  12. Deactivated User
    Sep 27, 2018
    ulats07 likes this.
  13. ulats07
    Eclair Sep 27, 2018
    like i mentioned,its working with p open beta 3,that make me wondering,what is the issue
  14. vele060
    Eclair Sep 27, 2018
    pie has a diferent approach handling the apps the developer has to update the core of the app to function with pie
    ulats07 and Deactivated User like this.
  15. vele060
    Eclair Sep 27, 2018
    dit you remove the app from the bat optimization?
    ulats07 likes this.
  16. nethanielrowland
  17. ulats07
    Eclair Sep 27, 2018
    this one,i tried both option,still not working,if you have some free time,can you try to install this app and try to open it,see if you having the same problem as i have
    thank you in advanced
  18. X1531817552743
    X1531817552743 , Sep 27, 2018 :
    why the systems storage is showing 9 GB I mean earlier my memory used was around 13gb and now it's 24gb used after update please any solution
  19. Strangeday_76
  20. G_Nelluri_Rakhil_Kumar_N
    Eclair Sep 27, 2018
    G_Nelluri_Rakhil_Kumar_N , Sep 27, 2018 :
    Double tap on screen wake up is coming but to lock is not coming.
