1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. rohitsharma_j22
    Gingerbread Sep 29, 2018
    rohitsharma_j22 , Sep 29, 2018 :
    If some music is playing on bluetooth speaker, in between if an incoming call recieved on phone, then after disconnecting call automatically previously playing music's volume getting high.
  2. sarus_b
    sarus_b , Sep 29, 2018 :
    No it doesn't, use the stock recording feature provided by oneplus
  3. G1527669637388
    Cupcake Sep 29, 2018
    G1527669637388 , Sep 29, 2018 :
    pls help on this
  4. Justin John
  5. sarus_b
    It was removed in pie by Google. I'm too disappointed by Googles decision.
    The good news is that any app can't use the sensors when its cached or in background.. So any app will use GPS only when its on foreground or when user is interacting with it.
    Vinay_NS likes this.
  6. Justin John
  7. prkoparkar
    Froyo Sep 29, 2018
    prkoparkar , Sep 29, 2018 :
    it's in utility section. I am on pie stable.
  8. prkoparkar
    Froyo Sep 29, 2018
    use file manager
  9. Marek_Orovnicky
    Honeycomb Sep 29, 2018
    Marek_Orovnicky , Sep 29, 2018 :
    sometimes between november and december
  10. prkoparkar
    Froyo Sep 29, 2018
    working fine in my phone
  11. Niklasg85
  12. Niklasg85
  13. F_Rushabh_Shah_King_mAWR
  14. PPApip
    Donut Sep 29, 2018
    PPApip , Sep 29, 2018 :
    -Can we remove the dark blur overlay on the lockscreen? I'd appreciate it if we get an option to turn off/on the blur on the lockscreen because I want to see my wallpaper the way it is.
    -Why are you trying to hide the notch in notification slider? There is this feeling of discontinuity of the status bar from the rest of the notification/quick settings. IMO the black bar (status bar) should be the same colour as the rest, and should only be black if the user opt for the no notch. It looks out of place.
    -Camera has a purple tint when shooting in video mode with the flash on (not using any case)
    -Shelf looks like a UI that was designed by someone who just started learning UI design. Need a little transparency so it doesn't look that bland like it just came out of ms paint.
    -Unlocking feels a little slower, very noticeable when using fingerprint. On Oreo, it detects my finger every single time in whatever orientation. No delay too. But in Pie, sometimes I had to do double take. Reconfiguring the fingerprint does not seems to help.
    im_Um_Ar and prkoparkar like this.
  15. ssanit
    Eclair Sep 29, 2018
    ssanit , Sep 29, 2018 :
    It happens to me too
  16. G_john_john1_zwRR
    Eclair Sep 29, 2018
  17. FaleshC
    KitKat Sep 29, 2018
    GambitM likes this.
  18. ananthu
    Froyo Sep 29, 2018
    ananthu , Sep 29, 2018 :
    Has anybody here noticed that the "App actions" feature is not available on the OnePlus 6? I thought it would be a Pixel exclusive and hence didn't report it during the initial beta phase. Now, my roommate's Nokia 7 Plus got the Pie OTA and he does indeed have the feature. Just wondering if I am the only one who misses it or is it something others would like to see as well? Tried out the pixel launchers and even the new Pixel 3 launcher and even though the option is enabled, it simply doesn't show up.
  19. kundan9120@gmail
    kundan9120@gmail , Sep 29, 2018 :
    after upgrading to Pie Bluetooth connection gettin disconnected and connected after certain interval.
    if else facing the same. pls suggest.
  20. G_Satya_Sai_3327
    Donut Sep 29, 2018
    Niklasg85 likes this.
