1291
OxygenOS 9.0 OTA for the OnePlus 6
  1. M1537638726720
    Cupcake Oct 3, 2018
  2. M1537638726720
    Cupcake Oct 3, 2018
  3. aykut39
    Honeycomb Oct 3, 2018
  4. Artemus.
    Community Hero 2020 Oct 3, 2018
    T1533225165147, Aks41179 and aykut39 like this.
  5. NeoFox69
    Cupcake Oct 3, 2018
    NeoFox69 , Oct 3, 2018 :
    Hello OnePlus users and team. I have a doubt. I have a OP 6 with the latest Android P oficial version and I would like to know if there's any way I can see when I receive a call, more contact information, such as Company, role job, etc... I have all that on contacts. thanks.
  6. T1532973895839
    Cupcake Oct 3, 2018
    T1532973895839 , Oct 3, 2018 :
    this is the problem were incoming call are showed not in full home screen and show in notification bar.so please complete this bug fix as soon as possible.thanks
  7. apoorvadonthi
    Froyo Oct 3, 2018
    apoorvadonthi , Oct 3, 2018 :
    Problems with pie to sum up:
    1. Screen brightness is reduced
    2. Battery drain
    3. Cache clearing option removed
    4. Hit and miss (mostly miss) feature of the screen rotate icon in the status bar when orientation is changed
  8. Aks41179
    Jelly Bean Oct 3, 2018
    Aks41179 , Oct 3, 2018 :
    And what do you suggest for resolving battery issues? What specific issues you have?
  9. Artemus.
    Artemus. , Oct 3, 2018 :
    1. Product of Pie. Get used to it or revert back to Oreo and never update your phone.
    2. Screenshots?
    3. You shouldn't be clearing it like that anyway.
    4. Are you using autorotate or Pie's rotation icon?
    Aks41179 likes this.
  10. G1530470080836
    Cupcake Oct 3, 2018
  11. Aks41179
    1. Screen brightness is reduced - read pinned FAQs
    2. Battery drain - read pinned FAQs
    3. Cache clearing option removed - read pinned FAQs
    4. Hit and miss (mostly miss) feature of the screen rotate icon in the status bar when orientation is changed - are you sure you are hitting it correctly?
  12. Aks41179
    phone is getting heated tremendously post upgrade - define tremendous
    airtel voice quality also degraded - contact airtel
  13. G1530470080836
    Cupcake Oct 3, 2018
    G1530470080836 , Oct 3, 2018 :
    more than oreo
  14. G1530470080836
    Cupcake Oct 3, 2018
  15. Artemus.
    What are you doing when your phone heats up?
  16. G1530470080836
    Cupcake Oct 3, 2018
  17. Artemus.
    Are you using the phone while it's charging?
  18. Aks41179
    Again, define tremendous. And need additional information Like temperature before and after. Are you using phone while changing? Playing graphic intensive games?
    B_Wrath likes this.
  19. G1530470080836
    Cupcake Oct 3, 2018
  20. G1530470080836
    Cupcake Oct 3, 2018
    i dont play games. it is only when chatting. i dont have leser thermometer to monitor tempeture
