1280
OxygenOS 9.0 OTA for the OnePlus 6
  1. Ravi_Singh_plus Donut Oct 11, 2018
  2. U1527434217943 Cupcake Oct 11, 2018
    U1527434217943, Oct 11, 2018 :
    lemme check...
  3. B1539071315624 Cupcake Oct 11, 2018
    B1539071315624, Oct 11, 2018 :
    There is no auto answer feature for Bluetooth headset in ONEPLUS 6.This is big issue.can anyone help me to solve this issue.
  4. T1534427219772 Cupcake Oct 11, 2018
    T1534427219772, Oct 11, 2018 :
    Since the new update I am facing a problem with my internet connection. Not able to load apps. Facing a lot of problems except for YouTube and facebook app . Rest all the other apps including WhatsApp, TOI,Economic times are either not loading or taking a lot of time in loading.
    This problem started after the new update.
  5. SoniaB Nougat Senior Moderator Oct 11, 2018
    SoniaB, Oct 11, 2018 :
    Thread merged with main release thread.
    Please note that as per forum rules, you should be posting in an existing thread, in this case the official thread for the latest update.
    You may want to try clearing your system cache.
  6. T1534427219772 Cupcake Oct 11, 2018
  7. ade0410 Honeycomb Oct 11, 2018
    ade0410, Oct 11, 2018 :
    the only problem that I have with Pie is that the weather/temperature on the home screen doesn't update like it did on Oreo. only when I open the weather app by clicking on it does it then update.
    any setting I should change?
    appreciate the adaptive battery closes apps no longer in use so maybe this is the problem.
    any help/advice.
    anyone else notice this?
    thanks.
  8. T1534427219772 Cupcake Oct 11, 2018
    please solve my case
  9. Elatchian Veeramani Gingerbread Oct 11, 2018
    Elatchian Veeramani, Oct 11, 2018 :
    Hello OP6 Bug hunters, We all provided enough bug which are notified after the 9.0 pie Update. We all are facing certain bug issues ( Don't say Battery, display brightness etc.) which can be resolved in further updates. So Kindly rollout Next Os 9.0.5 or 9.0.1update as soon as possible as a stable versiom.
    Give solution for some Stability issues, lags in few areas, Notification bar problem in last Android update . Kindly Rollout a new update before launching 6T becz the former has to be bug free so that 6T stable version will be bug free.
    Note: I know this post may not reach Dev's . But just a way to initiate the things.
  10. Maaz.saif Froyo Oct 11, 2018
    Maaz.saif, Oct 11, 2018 :
    its working fine for me.
  11. Maaz.saif Froyo Oct 11, 2018
    goto the battery setting then battery optimisation, then advance optimisation. then turn off both optimisation.will fix the issue. no network problem no call drop no fingerprint problem. all will work fine.
  12. Maaz.saif Froyo Oct 11, 2018
    the only thing u need to do is turn off advance battery optimisation. there u will find 2 options . disable them. fingerprint issue call drop issue network issue will be resolved
    kshgarg likes this.
  13. F1519734270787 Froyo Oct 11, 2018
    F1519734270787, Oct 11, 2018 :
    Hey OP Team,
    If you are listening me then i am very sorry and disappointed to write this. I am an OP user since OP5 (I have used op5, 5t, and now op6) and now after upgrading to Android pie in OP6 i am facing too many issues and these are listed below
    1. Display brightness issue. Auto brightness not working properly.
    2. It takes more time in camera shutter time than before.
    3. Mobile network issues, wifi connection issues, call drop issue.
    4. Battery drains fast than before.
    5. Camera resolution is not good.
    We are using a premium flagship phone and we didn't expect this type os issues. Don't losses your customers to sell your next upcoming model. We are your end users. We don't take so much time to shift into another brand.
    F1538737190508 and Astbomba like this.
  14. Maaz.saif Froyo Oct 11, 2018
    8238060001
    which is compatible call recording app? previous one is not working after updating with oxygenOS 9.0?​
    OnePlus 6 hv its own . go to call setting there u will find call recording option
  15. DincaDaniel Cupcake Oct 11, 2018
    DincaDaniel, Oct 11, 2018 :
    Hello so I have a lot of problems with my mobile network lately. Every call is connecting very slow and when it finally connects it is not clear and is interrupting. I am on Telekom Romania. Are you aware of this problem and if so when will you fix it?
  16. ngydat KitKat Oct 11, 2018
    ngydat, Oct 11, 2018 :
    There's no One Plus team here. Only users like you and I
  17. Manimaran Eclair Oct 11, 2018
  18. Harry_96 Froyo Oct 11, 2018
  19. Dany21000 Eclair Oct 11, 2018
    Dany21000, Oct 11, 2018 :
    For me, the brightness bar in quicksettings must be on the upper, rapidly adjustable with one gest.
    Here, we have to two gest to slowdown the full qui setting to get the bar...
  20. iamsumitversatile Donut Oct 11, 2018
