1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. shravan chittoor
    Cupcake Oct 23, 2018
  2. palpawan83
  3. Solankiajay
    Solankiajay , Oct 23, 2018 :
    i have using this phone about fpur months but this update really suck.
    1. BRIGHTNESS IS REALLY LOW
    2. CLASH ROYALE DIDN'T SHOW IN FULL SCREEN
    3. NOW ASPHALT 8 DIDN'T SUPPORT FULL SCREEN MODE
    OH, MAN I DIDN'T NEED SPEED JUST IMPROVE YOUR UPDATE .
  4. Cervantes
    Lollipop Moderator Oct 23, 2018
    Cervantes , Oct 23, 2018 :
    Please read first, second and third post
    You can reset networks and/or erase temporary memory: wipe cache
    And the forum rules
    Thread merged
  5. G_suyash_patwardhan_xxZS
    G_suyash_patwardhan_xxZS , Oct 23, 2018 :
    doze mode is not working properly on my op 6 running oxygen os 9.0 it is loosing considerable amount of battery even when iam not using it
  6. Deactivated User
    Oct 23, 2018
  7. M1540269596440
    M1540269596440 , Oct 23, 2018 :
    I'm a very new user of OnePlus 6. first few day s when I used with Android oreo the battery was good. but after upgrading to pie my battery draining like anything. even in standby mode the battery requirement is same as screen time. is it my battery problem . my device is only 15 days old.
  8. G_suyash_patwardhan_xxZS
    I have a same problem..
  9. susheelreddy
    Eclair Oct 23, 2018
    susheelreddy , Oct 23, 2018 :
    Was excited to upgrade to Android Pie, i was not happy somehow.
    it was really tough to get back to Oreo had to visit Service centre and reload the older OS
    problems in Pie
    1) Multitasking hate that view. please give option to use the older version of switching between apps instead of card style apps
    2) Dialer app need older version. the UI is bad
    3) the Volume button UI , need to get the drop down option to change Alarm , Ringer , media volumes.
    4) better looking volume bar make it as small as possible.
    #OnePlus6 #Android
    #OxygenOS
  10. Kashtekar
    Kashtekar , Oct 23, 2018 :
    Audio does not stop automatically after a bluetooth device is disconnected. Please atleast provide an option to do so.
  11. Navneet Bhargava
    Honeycomb Oct 23, 2018
    Navneet Bhargava , Oct 23, 2018 :
    fine, except caller ui rest of them are given form google ans it is part of pie os, you have to use as it is or else download 3rd party applications like nova launcher.
  12. B_Wrath
    Marshmallow Oct 23, 2018
    B_Wrath , Oct 23, 2018 :
    This is not Facebook to create a post and share what's in your mind... You could have posted this in the pie announcement thread... Why create a new thread??
    U1537305495703 likes this.
  13. susheelreddy
    Eclair Oct 23, 2018
    thank you. but I didn't know about it. will do it over there.
  14. susheelreddy
    Eclair Oct 23, 2018
    problems in Pie
    #OnePlus6 #Android
    #OxygenOS
    Solankiajay likes this.
  15. FaleshC
    KitKat Oct 23, 2018
    FaleshC , Oct 23, 2018 :
    1. Not happening, Google did it!!
    2. Its okay, users usually don't stare at call screen for long. will welcome any cosmetic change though.
    3. Google did it.
    4. Google did it, no problems with that.
    and yeah a simple flash of downgrade package would have done the trick, but you decided to visit Service center, your call.
    LegolasX and GambitM like this.
  16. palpawan83
  17. susheelreddy
    Eclair Oct 23, 2018
    nope. flash didn't work.
  18. Dragos Roos
    Eclair Oct 23, 2018
    Dragos Roos , Oct 23, 2018 :
    Hi! Does anyone know if Android Pie will let you screen capture videos straight from your phone and allow to record the sound through internal audio? For the moment at 8.1 says can only record through your speakers...which i don't like.
  19. Miniterror
    Froyo Oct 23, 2018
    Miniterror , Oct 23, 2018 :
    Got my girlfirend a Oneplus 6 and so far she is happy with it.
    Running version 9.
    What i did it unbox the device and update it to latest version.
    After i updated i factory resetted the device and then let her set it up.
    All you people with problems, have you tried to factory reset it?
    You guys have updated to a new major version where a lot has been changed under the hood.
    Usually with major updates you need a factory reset of the system to have things working properly.
    chazey2 likes this.
  20. chazey2
    Jelly Bean Oct 23, 2018
    chazey2 , Oct 23, 2018 :
    Bet most haven't they expect it all to just work perfect with no input from themselves. The Android version update is the key point here! Afraid a high percentage of OPlus users seem to fall into this category.
