1294
OxygenOS 9.0 OTA for the OnePlus 6
  1. FaleshC
    KitKat Sep 22, 2018
    FaleshC , Sep 22, 2018 :
    not if you moving from 5.1.11 to Pie.
    Vladut123 likes this.
  2. as_if_i_am
    Gingerbread Sep 22, 2018
    as_if_i_am , Sep 22, 2018 :
    thanks buddy , Can't wait so thought to switch server of VPN like old times. But no luck. Will wait.
  3. amitdate
    amitdate , Sep 22, 2018 :
    Exactly. So I was asking if there are "some people' for whom VPN has worked. Anyways I never asked you specifically, so please let me alone
  4. Moe Di
    Cupcake Sep 22, 2018
  5. Deactivated User
    Sep 22, 2018
    sanghanijd and Vladut123 like this.
  6. durgraj17
  7. zeekazi26
    Donut Sep 22, 2018
    zeekazi26 , Sep 22, 2018 :
    further the single home button which also act as slider for switching between recent apps is difficult to find
    all in the recent app switcher were live in beta such as in the app switcher one can copy text etc directly through the app switcher without opening the app.
  8. D1532371210175
    deviantartjr and Vladut123 like this.
  9. amitdate
    That's ok. please don't be rude then. You could have simply answered "Yes" or "No". It was close ended question anyway
  10. Venkatesh Nayak A R
    Venkatesh Nayak A R , Sep 22, 2018 :
    updated beta versions only when they said ...
    now I will get the android pie 9 version ...or thats the end ...can anyone know about this
    ...but system updates showing upto to date?
  11. ashajethro
    Donut Sep 22, 2018
    ashajethro , Sep 22, 2018 :
    hi.. I also facing can't upgrade bcoz it's a lower zip.
    so now I need to download & install 5.1.11 first and then 'only' reboot and after that go upgrade the 9 stable zip then factory reset?
    bcoz if I'm not mistaken if I factory reset in the 5.1.11 I will lose my previous downloaded file.
    need advice please.
  12. Deactivated User
    Sep 22, 2018
  13. Kasyap Girijan
    Eclair Sep 22, 2018
    Kasyap Girijan , Sep 22, 2018 :
    we won't be getting stable the MP update trough OTA need to download the stable ROM from official downloads.oneplus.com and flash the stable MP ROM..with full data wipe ... however they haven't uploaded the ROM to offical page just wait for it.
    open beta 4 ..not sure about it ..
  14. venkar13
    Froyo Sep 22, 2018
    venkar13 , Sep 22, 2018 :
    i got the update again no battery percentage style in the notification bar and the os seems very slow now
  15. jrjadeja
    jrjadeja , Sep 22, 2018 :
    after update of android pie in my OP6, there is no option of clear cache in Setting > Storage > Clear Cache
    How to clear cache??
  16. Somanath_Deepak
    Donut Sep 22, 2018
  17. Deactivated User
    Sep 22, 2018
  18. B_Wrath
    Nougat Sep 22, 2018
    B_Wrath , Sep 22, 2018 :
    You updated to beta on your own... It was never pushed to anyone....
    You will get beta updates now...
    If you want to move back to stable, wait till they roll out the package in the official download section of OnePlus website... You can use it... But it will wipe your data...
  19. venkar13
    Froyo Sep 22, 2018
  20. sumitMZ007
    Jelly Bean Sep 22, 2018
    sumitMZ007 , Sep 22, 2018 :
    screen on time is reduced.. earlier for 1% battery use . SOT WAS 7 MIN. NOW IT'S 5MIN.FOR SAME LEVEL OF USAGE..#ANDROID9PIE
