451
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. salvasad Froyo Jul 8, 2019
    salvasad, Jul 8, 2019 :
    ok ty [e]1f44d[/e]
  2. David Turney Gingerbread Jul 8, 2019
    David Turney, Jul 8, 2019 :
    something has def changed since the since the update
  3. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Jul 8, 2019
    KeepTransisting, Jul 8, 2019 :
    That's what Smart Lock is. That's not an issue. That's working as intended.
  4. Soulbruva Froyo Jul 8, 2019
    Soulbruva, Jul 8, 2019 :
    I've found out to show the ambient display I need to double tap the screen but it doesn't work all the time. I think the edges don't recognize the tapping or at least the sensitivity has been reduced significantly. Is it a way to avoid accidental touches?
  5. David Turney Gingerbread Jul 8, 2019
    I did as you suggested and it is now working, just double tap. although it seems to be sporadic. I will live with it for a while and see how it goes. thanks for all your help.
  6. tom_vo Gingerbread Jul 8, 2019
    tom_vo, Jul 8, 2019 :
    I deactivated the single tap (ambiant display) and activated the double tap (gestures). I wiped cache and restarted and it still won't work. Any ideas?
  7. Ippolito1971 Honeycomb Jul 8, 2019
  8. salvasad Froyo Jul 8, 2019
    hmm read a few message back someone telling to turn all wakeup options off and than choose one
  9. tom_vo Gingerbread Jul 8, 2019
    I tried too but it still won't work
  10. acheney1990 Donut Jul 8, 2019
    acheney1990, Jul 8, 2019 :
    Can also confirm. Tap to wake isn't working. Frustrating cause I use it all the time.
    geo07, TomekDarda and tom_vo like this.
  11. salvasad Froyo Jul 8, 2019
    hmm weird i had the aame but workt later for me
  12. David Turney Gingerbread Jul 8, 2019
    it's very sporadic. I even try to restart and that didn't change anything it's so sporadic. something in the update is messed up I know they fiddled with sensitivity so I'm guessing it has something to do with that. it may take another update to get it right.
  13. Popetillox Cupcake Jul 8, 2019
    Popetillox, Jul 8, 2019 :
    Installed and ok!! BIG TNX!!
  14. R1558910837372 Froyo Jul 8, 2019
  15. Swejuggalo Jelly Bean Jul 8, 2019
    Swejuggalo, Jul 8, 2019 :
    I prefer the ambiant screen tap and have all the other wake up settings off. It let's you unlock and you see if there are any apps with notifications. All I need.
    MValdez24 likes this.
  16. rclotz Honeycomb Jul 8, 2019
    rclotz, Jul 8, 2019 :
    I also tried that but it doesn't work.
    That's weird because I didn't have any issues on 9.5.8.
    I will later try to install the full version on more time.
  17. salvasad Froyo Jul 8, 2019
    Try this... Turn of all the wake up options, lifting up the phone, double tap and one tap. Then just select double tap. Does it make a differans?
    if that dosent work i dont know than sorry
  18. rclotz Honeycomb Jul 8, 2019
    Yes, that's true.
  19. KrishnaK98 Cupcake Jul 8, 2019
  20. Soulbruva Froyo Jul 8, 2019
    Ok I got the "tap the screen to show" feature to work BUT only if you disable the "pick up your phone to show" feature. The sensitivity around the edges are greatly reduced presumably to avoid accidental touches.
