451
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. FRJerome
    Ice Cream Sandwich Jul 21, 2019
    FRJerome , Jul 21, 2019 :
    Good phone yes
    Better than the op7pro no
    Snapdragon 845
    No 90hz
    Notch
    And no oxygen OS
    I wouldn't change my op7pro for a V40 at all
  2. S1558166257733
    Cupcake Jul 21, 2019
  3. FRJerome
    C'est mieux de poster en anglais ici
    Pour la seconde de retard ... Ça me semble très excessif
    Il y a un petit lag c'est vrai mais tout sauf gênant
    Plusieurs choses
    Pour les macro utilise le mode pro et tu as un mode macro
    Pour les photos en mouvement utilise le mode rafale
    Pour ma part que ce soit du portrait ou du paysage je trouve que cet appareil s'en sort très bien. Y compris sur du mouvement a partir du moment où tu as assez de lumière.
    Pour moi c'est sans conteste au dessus du 6T
  4. Z1561831901383
    Donut Jul 21, 2019
    Z1561831901383 , Jul 21, 2019 :
    hey guys, I received this update on my gadget.
    please tell should I continue....or is there any problems on this update
  5. CollieDog
  6. V1529168106709
    Gingerbread Jul 21, 2019
    V1529168106709 , Jul 21, 2019 :
    better battery backup after 9.5.10 update I guess 5 hrs SOT with Pubg and Asphalt 9 for 30 mins each plus other apps used ....36% battery left which means min 2 hrs more
  7. akks
    akks , Jul 21, 2019 :
    Although I don't play games, I too felt battery life has increased with the update. I usually used to charge everyday morning at 7 am when my charge used to be around 10%. But now it almost always remain around 30% when I connect to charger at 7am.
    Exactly same usage. I don't believe much in SoT.
    V1529168106709 likes this.
  8. G_Hau_Billy_3T
  9. Swejuggalo
    Jelly Bean Jul 21, 2019
    Swejuggalo , Jul 21, 2019 :
    What do you mean?
    I can wake up Google Assistant several ways and it works for me
  10. Sahil.budhwar123
    Eclair Jul 21, 2019
  11. Vinsten Leon
    Vinsten Leon , Jul 21, 2019 :
    I purchased my one plus 7 pro yesterday and it had the 9.5.4 build in it,later on i got an ota update for the 9.5.10 build, assuming it contained the previous updates I installed it, but the features from the previous updates are missing,for eg. the pop up camera popping up on it's own when a video call is made and etc.
    Any suggestions on how I could get the previous builds or something, please help me out.
  12. FRJerome
    Everything is included
    No feature can be missing
  13. Vinsten Leon
  14. Swejuggalo
    Vinsten Leon
    unfortunately it is missing , any suggestions as to what I shall do?‍♂️​
    Is the phone locked and screen is off when the camera pops up? What app(s)? Using Smart Unlock?
  15. Vinsten Leon
    nope not using smart Lock just the regular inbuilt app locker. camera pops up as soon as I unlock.
  16. Ömer Talha Özkan
    Donut Jul 21, 2019
  17. mosyn2k
    Froyo Jul 21, 2019
  18. Swejuggalo
    I assume 9.5.6 will come within a reasonable time
  19. rclotz
    Honeycomb Jul 21, 2019
    rclotz , Jul 21, 2019 :
    The feature is that the camera pops up when the phone is unlocked and a video call comes in.
    If the phone is locked and display off the camera doesn't pop up.
    Vinsten Leon and FRJerome like this.
  20. Ga22
    Ga22 , Jul 21, 2019 :
    Hey people, what the current latest software on the OnePlus 7 pro?
