453
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. HZ_ND
    Gingerbread Jul 23, 2019
    HZ_ND , Jul 23, 2019 :
    Because you do charge in between use.. Try not charging your phone till ilyournphone gets drained to 1 percent and see your sot. Plz redo ur battery usage without charging your phone in between.
  2. Rye_ry
    Donut Jul 23, 2019
    Rye_ry , Jul 23, 2019 :
    Thank u for this.
    HZ_ND likes this.
  3. HZ_ND
  4. DaKNIGHT
    Froyo Jul 23, 2019
    DaKNIGHT , Jul 23, 2019 :
    It could be because you have set up a trusted device which is connected to it.
    Try revoking trusted device permission
    mine works perfectly even after update
  5. HZ_ND
    No any trusted device with me.. Not my Bluetooth headset or my Bluetooth watch.. I never set it up b4. This
  6. NaokiP
    Donut Jul 23, 2019
  7. Soulbruva
    Soulbruva , Jul 23, 2019 :
    I didn't charge my phone in between
  8. Rye_ry
    Donut Jul 23, 2019
    Maybe beccause of my bluetooth earbuds, when I disconnect it.It works properly now
    HZ_ND likes this.
  9. HZ_ND
    The graph on your battery indicator shows a steady bit increase charge.
  10. lucifer3036
    Froyo Jul 23, 2019
    lucifer3036 , Jul 23, 2019 :
    Check if you have smart lock enabled. Setting -> Security & Lock screen -> Smart Lock.
  11. H1563857414936
    Cupcake Jul 23, 2019
    H1563857414936 , Jul 23, 2019 :
    hi i know this is old..but i just bought op7pro its on 9.5.4 .got system update to 9.5.10..will i miss the 9.5.7 camera improvement?
  12. Soulbruva
    no it doesn't. it's virtually a straight line. I haven't been using my phone at that time. I can leave my phone for like 2 hours and not more than 2% gets drained
    HZ_ND likes this.
  13. apat26
    Froyo Jul 23, 2019
    apat26 , Jul 23, 2019 :
    No. Never.
    H1563857414936 likes this.
  14. rclotz
    Honeycomb Jul 23, 2019
    rclotz , Jul 23, 2019 :
    No.
    You will get all improvements with 9.5 10
  15. HZ_ND
    H1563857414936
    hi i know this is old..but i just bought op7pro its on 9.5.4 .got system update to 9.5.10..will i miss the 9.5.7 camera improvement?​
    No you won't miss it.. Because you do have the improvement of previous update on 9.5.10
  16. ssaikiran92
    ssaikiran92 , Jul 23, 2019 :
    If adaptive brightness is not working, reset it by going into "Device Health Services" app settings -> Clear Storage -> Reset adaptive brightness. Then it will start learning again to your usage. I am having no issues with adaptive brightness
    vsathishk, JayantMorghade and HZ_ND like this.
  17. Rahul.09
    Rahul.09 , Jul 23, 2019 :
    I received an update and I put it to download and then suddenly it vanish I can't see it anymore neither did it get installed is some bug with the update ?
  18. HZ_ND
    Will try and see whether it will help or not.
  19. W1563862587284
  20. Aathif_Mahir
    Ice Cream Sandwich Jul 23, 2019
    Ömer Talha Özkan likes this.
