453
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. P1561589408180
    Donut Jul 25, 2019
    Shalin235 likes this.
  2. Shalin235
    Gingerbread Jul 25, 2019
    Shalin235 , Jul 25, 2019 :
    Battery Drain is Present on 9.5.10 below are my screenshots. (MI FIT & GOOGLE PLAY SERVICES) Battery draining alott.
  3. Bossei
    Cupcake Jul 25, 2019
    Bossei , Jul 25, 2019 :
    I've experienced the same thing. Although I had the double tap issue with an active call on previous updates too. it's really annoying.
  4. Bernest44
  5. djaidyc
    Eclair Jul 25, 2019
    djaidyc , Jul 25, 2019 :
    For me this is bar far the best phone I've used for battery life. I've not had an issue with battery drain at all. I do restrict which apps can run in the background though (apps I don't use on a daily basis).
  6. itskapil
    Donut Jul 25, 2019
    itskapil , Jul 25, 2019 :
    What fix is that? Pls share a link if you can. Thank!
  7. Moin2200
    KitKat Jul 25, 2019
  8. scmurphy13
    scmurphy13 , Jul 25, 2019 :
    My adaptive brightness sucks even more now. My screen will just randomly go very dim for a few seconds and then get bright again. Didn't do that before this update.
    W1541536202739 and noexcusses like this.
  9. Bossei
    it should. there are problems being experienced..
  10. H1542153384332
  11. Bernest44
    Bernest44 , Jul 25, 2019 :
    No it is not....it is both. I'm 110% sure. I have it.
  12. H1542153384332
    H1542153384332 , Jul 25, 2019 :
    The T-Mobile 9.5.9 was nothing more than an Android security update. Which was all T-MOBILE listed in the update. Nothing changed on my phone. Camera version didn't change.
  13. Bernest44
    My battery life was the most noticable. Camera tested better and no glitches or ghosting.....I know it was a fix as my battery life itself right after the update was crazy good.....a 24 hour difference! Your update indeed was NOT an OxygenOS update.
  14. Bernest44
    My question would be....if I downloaded the 9.5.9 from TMobile....now OnePlus has the 9.5.10 for download on their site. Am I better off downloading this even though I have the 9.5.9? Will I benefit?
  15. jon_a_ward
    Donut Jul 25, 2019
    jon_a_ward , Jul 25, 2019 :
    the autofocus in portrait mode is very poor. this needs to be improved it is to become a useful feature. also the ability to change the level of blur after the shot has been taken would be a very "nice to have" ability.
  16. Gertjan@
    Gertjan@ , Jul 25, 2019 :
    Here the same!
    Predict23 and wospino like this.
  17. josejar92
    Eclair Jul 25, 2019
    josejar92 , Jul 25, 2019 :
    You would benefit as 9.5.9 for TMO was just a security patch. features released on 9.5.10 are missing on the TMO version.
  18. wospino
    Ice Cream Sandwich Jul 25, 2019
    wospino , Jul 25, 2019 :
    same here, auto brightness sucks
    W1541536202739 and Predict23 like this.
  19. javito0992
    Donut Jul 25, 2019
  20. H1542153384332
    if you received the ota update from T-Mobile you only received a security patch. I don't know how you were able to download anything but a security patch from T-Mobile. As far as battery life goes I go all day with ease since I've had this phone.
