451
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. Swejuggalo
    Jelly Bean Jul 28, 2019
    Swejuggalo , Jul 28, 2019 :
    Does "visual voicemail" sound familiar?
  2. L1564305628925
    Cupcake Jul 28, 2019
  3. L1564305628925
  4. Swejuggalo
    L1564305628925
    this much app in my phone
    You have given all the needed permissions to the app?
    Some pointed out in one case that logging out from the Google account in settings, accounts and logging back in helped. I don't see a logout but I guess you could remove the account and add it again.
    When did it start happening?
    Edit: Found more cases of phone apps (not just Oneplus devices) crashing and fixed by several types of contacts syncing gone bad... Remove accounts that syncs contacts and add them again if really needed.
    You could also remove one app at a time (especially all communication apps) one at a time and try the phone app. Reinstall if it did not make a differance.
  5. roarwolfy
    roarwolfy , Jul 28, 2019 :
    The volume rocker only adjusts media volume. Thats a Android 9 problem. To adjust ringer volume hit the volume rocker to bring up the media adjustment, tap on the gear (settings) icon. From there you get two other volume options to adjust volume. Ringer will be one of them in there. My ringer volume is extremely loud on my 12GB 1+7 Pro
    Santosh.Udyavara likes this.
  6. Y1563216770166
    Donut Jul 28, 2019
  7. G1564351194108
    Eclair Jul 28, 2019
  8. H1542153384332
    Gingerbread Jul 28, 2019
    H1542153384332 , Jul 28, 2019 :
    The T-Mobile 9.5.9 is nothing more than a Android security update. Nothing more nothing less. It won't do you any good but call T-Mobile or spam them on Twitter and Facebook. iPhone and Samsung are the phones TMobile pushes on it's customers.
  9. G1564351194108
    Eclair Jul 28, 2019
    G1564351194108 , Jul 28, 2019 :
    so when will I see a real update and why is my battery life horrible now
  10. A1560648267550
    Froyo Jul 29, 2019
    A1560648267550 , Jul 29, 2019 :
    Something might not be playing friendly with the new update, I'm on that same version but haven't had battery issues. We're still waiting for the 9.5.10 update I wouldn't be surprised if it comes this week or the following.
    G1564351194108 likes this.
  11. maazkazi1991
    Froyo Jul 29, 2019
  12. Rahatg
    Donut Jul 29, 2019
    Rahatg , Jul 29, 2019 :
    Oneplus 7 pro is device that is getting most stable frame rates. Continues hits 59 frames on hdr + extreme. Their is no such issue on oxygen os. Try reinstalling game
    H1542153384332 likes this.
  13. V1529168106709
    Gingerbread Jul 29, 2019
    V1529168106709 , Jul 29, 2019 :
    take it to nearest SC.... my phone doesn't have such issues
  14. H1561960043803
    Honeycomb Jul 29, 2019
    H1561960043803 , Jul 29, 2019 :
    ok. quick question. I am now sim unlocked, and the oxygen updater will let me flash 9.5.10. I am still on TMobile us os...will this convert me to international os ? or do I need to go to that site we know and love and flash internation os before using the updater? at least it will let me flash now. before it just said my device was un supported.
  15. MrTomatico
    Donut Jul 29, 2019
    MrTomatico , Jul 29, 2019 :
    I am having problems with the battery. in all cycles this situation is always repeated. I tried WhatsApp beta and stable ...
  16. akshaxpatil
    Donut Jul 29, 2019
  17. vriesdejoop
    Ice Cream Sandwich Jul 29, 2019
    vriesdejoop , Jul 29, 2019 :
    as long as you do it in the right forum....
  18. Swejuggalo
    Jelly Bean Jul 29, 2019
    Swejuggalo , Jul 29, 2019 :
    Let me know if it was solved and what the solution was.
    If not you might want to try out factory reset. But to exclude 3rd party apps from being the root of the issue I'd recommend not to restore everything but start from fresh and adding apps manually.
    Try out the phone app before starting to install any apps.
  19. Santosh.Udyavara
    Cupcake Jul 29, 2019
    Santosh.Udyavara , Jul 29, 2019 :
    it's a complete letdown with OP7...I took it in India before flying to Europe and now I'm stuck with so many issues.. it's completely regressed from OP5..I started with OP3 TO OP5 and now OP7pro.. maybe it was too big a leap of faith and I should've tried the RedminK20 at half the price instead
  20. V1529168106709
    not sure what's the issue. I have many friends using OP7 and none have any issues
