452
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. Santosh.Udyavara
    Cupcake Jul 29, 2019
    Santosh.Udyavara , Jul 29, 2019 :
    Bluetooth has completely broken... unless the newest update is the issue.. have GM21AA
  2. V1529168106709
    Gingerbread Jul 29, 2019
    V1529168106709 , Jul 29, 2019 :
    did you fiddle with the OS?
  3. Santosh.Udyavara
  4. V1529168106709
    very strange...try factory reset
  5. heartsnacker
  6. Swejuggalo
    KitKat Jul 29, 2019
    Swejuggalo , Jul 29, 2019 :
    What carrier and did it work before the update?
  7. heartsnacker
  8. Swejuggalo
    KitKat Jul 29, 2019
    Read about some users having lost VoLTE by updating. Did that happen to you too?
  9. heartsnacker
    heartsnacker , Jul 29, 2019 :
    yes wid me even I lost my volte thing
  10. Swejuggalo
    KitKat Jul 29, 2019
    If you didn't use any hack or stuff to make it work last time it's probably a bug. You could report it with the feedback tool in the community app
  11. heartsnacker
  12. Swejuggalo
    KitKat Jul 29, 2019
    Ah I see. Verified that you rolled back to global firmware? AA
  13. heartsnacker
  14. Swejuggalo
    KitKat Jul 29, 2019
    Unless you got it to work on 9.5.10 before it's probably that specific version that of some reason is lacking the profile nessesary to make it work. Report that to Oneplus.
  15. Oneplus suman
    Froyo Jul 29, 2019
    Oneplus suman , Jul 29, 2019 :
    same problem facing for me...but I called to Airtel customer care and request for activation volte feature for my sim... next day volte feature automatically enabled...plz contact customer care.. I'm sure that ur problem will be solved..
  16. A1560648267550
    A1560648267550 , Jul 29, 2019 :
    I would flash international before doing the update, just as a precaution.
    H1561960043803 likes this.
  17. A1560648267550
    just do a backup before as it will wipe everything!!
  18. heartsnacker
  19. Swejuggalo
    KitKat Jul 29, 2019
    You have a problem with that during calls?
  20. heartsnacker
