453
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. F_Shaswat_Swarup_Sahoo_W
    Eclair Jul 9, 2019
    F_Shaswat_Swarup_Sahoo_W , Jul 9, 2019 :
    Actually, I tried automatic brightness by turning on the lights in a completely dark room and then turning the lights off. Once the brightness level is high it doesn't decrease the level in low brightness areas. I needed to switch to auto brightness mode again to make it work.
    F1536011049830 likes this.
  2. NeoElettoTheOne
    Froyo Jul 9, 2019
  3. mikkado
    Gingerbread Jul 9, 2019
    mikkado , Jul 9, 2019 :
    [QUOTE = "H1561960043803, post: 20528876, member: 2204181"] ils savent [/ QUOTE]
    Bah non chez moi ça fonctionne très bien
  4. JagdeepSingh02
    Froyo Jul 9, 2019
    JagdeepSingh02 , Jul 9, 2019 :
    read what if you have the answer then explain, because there isn't a universal method to solve it
  5. markokinnu
    markokinnu , Jul 9, 2019 :
    I can't be any happier with my OP7Pro everything is just so creamy [e]1f601[/e]
    G.Reagon likes this.
  6. idbl_fanatic1
    Ice Cream Sandwich Jul 9, 2019
    idbl_fanatic1 , Jul 9, 2019 :
    Read through the post, You have to choose
  7. Sea_wolf
    Froyo Jul 9, 2019
    Sea_wolf , Jul 9, 2019 :
    I can suggest to be patient and wait for OTA update which will come automatically. Hopefully everything will work fine there.
  8. JagdeepSingh02
    Froyo Jul 9, 2019
  9. G_Raj_Chowdhury_KjDf
    Eclair Jul 9, 2019
  10. idbl_fanatic1
    make sure tap to ambient display option is disabled
  11. JagdeepSingh02
    Froyo Jul 9, 2019
  12. JagdeepSingh02
    Froyo Jul 9, 2019
    only thing that I can think is that the phone is trying to learn how and where we tap so that it doesn't wake up with every touch...
  13. E1560338111654
    Cupcake Jul 9, 2019
    E1560338111654 , Jul 9, 2019 :
    yo aún no puedo actualizar, y sigo con mis toques fantasmas la barra de aplicaciones no me deja bajarla en aplicaciones y todo esto con el NFC desactivado, se me baja la barra de aplicaciones sola cuando estoy en wasap o Instagram y se acaba metiendo en los ajustes de la batería, las historias de Instagram se me saltan solas para atrás o para adelante según le de, y ya llevo así un tiempo, y en el wasap a veces ni escribir puedo.
  14. contentryder
    Cupcake Jul 9, 2019
    contentryder , Jul 9, 2019 :
    thanks for fixing the proximity sensor when on call! screen actually stays off when close to ear now, as it should.
    Deactivated User likes this.
  15. NeoElettoTheOne
    Froyo Jul 9, 2019
    NeoElettoTheOne , Jul 9, 2019 :
    FOR EVERYONE HAVING PROBLEMS WITH SINGLE/DOUBLE TAP TO WAKE,TRY THIS:
    -SETTINGS
    -APPS AND NOTIFICATIONS
    -SHOW ALL APPS
    -TAP THE THREE DOTS ON THE UPPER RIGHT CORNER
    -SHOW SYSTEM APPS
    -TAP "AMBIENT DISPLAY"
    -DELETE CACHE
  16. Sr.D
    Donut Jul 9, 2019
    Sr.D , Jul 9, 2019 :
    when are we going to get landscape orientation in the home screen and native apps?
  17. [email protected]
    Honeycomb Jul 9, 2019
  18. V1544629925015
    V1544629925015 , Jul 9, 2019 :
    What you mean? In the gestures?
  19. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jul 9, 2019
    KeepTransisting , Jul 9, 2019 :
    Probably not. Most stock launchers don't have landscape homescreen options. You can always get a third party launcher like Nova Launcher if you want that.
    Just because it was in the Hydrogen update doesn't mean it's going to be in the Oxygen update
  20. [email protected]
    [email protected] , Jul 9, 2019 :
    swipe back from the left or right side screen, not from the Bottom.
