453
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. Shivalik_Rana
    Cupcake Jul 9, 2019
    anandthama02 likes this.
  2. V1544629925015
    Gingerbread Jul 9, 2019
  3. [email protected]
    Honeycomb Jul 9, 2019
    [email protected] , Jul 9, 2019 :
    swipe from the Bottom, i mean from the edge side of the screen, not the Bottom side
  4. D1562704692571
    Cupcake Jul 9, 2019
    D1562704692571 , Jul 9, 2019 :
    Facing too many issues of App crash, common being "Snapchat is unable to open camera restart app or device" , other apps get hung alot too, apps get refresh if I switch to other app and come back to first app even after less than a minute. Highly unexpected from such a high end device.
  5. Y1557911479138
    Cupcake Jul 9, 2019
    Y1557911479138 , Jul 9, 2019 :
    Made it so insensitive, to pull the notification drawer or home bar at the bottom up in gaming mode takes me at least 5 angry strokes..... Awful update will rollback
  6. NeoElettoTheOne
    Froyo Jul 9, 2019
    NeoElettoTheOne , Jul 9, 2019 :
    Lock your screen,wait 10 seconds,tap to wake.
    For me it's working.
    Hitman424 likes this.
  7. Headcleaner67
    Froyo Jul 9, 2019
  8. idbl_fanatic1
    Ice Cream Sandwich Jul 9, 2019
  9. Vin619
    Eclair Jul 9, 2019
    Vin619 , Jul 9, 2019 :
    Wow just updated before i went to sleep and i think it improved battery performance its lunch time at work and im at 82% usually im at 75% or lower by this time, so far I dont have bugs like the single tap problem I dont see any big improvements on the camera thou will test later... All i got to say to the dev team thanks
    pvitale, Hitman424 and roryrudy like this.
  10. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 9, 2019
    Swejuggalo , Jul 9, 2019 :
    I haven't been able to see any loss in sensitivity for me. Tried it many times in game mode with no problems.
  11. LireLidmire
    Cupcake Jul 9, 2019
  12. Aramalp
    Eclair Jul 9, 2019
    Aramalp , Jul 9, 2019 :
    same here .
    7 pro 12 gig ram
  13. SeaRefractor
    SeaRefractor , Jul 9, 2019 :
    Whenever I've had updates in the past on my prior Samsung phone, I had to power off and go into the bootloader to wipe the cache partition. I've carried that automatic response to OP 7 Pro after migrating phones and I've not yet had issues with the updates.
    I found this guide from T-Mobile, but I'm sure there's one here as well. https://support.t-mobile.com/docs/DOC-40182
    I'm sure that this was stated before, but the search tool on this site doesn't extend to searching this thread only, so apologies for the repost if already covered.
  14. idbl_fanatic1
    idbl_fanatic1 , Jul 9, 2019 :
    1. Turn off your device.
    2. Press and hold the Volume down and Power button at the same time.
    3. When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    4. At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    5. Tap English.
    6. Tap Wipe data and cache.
    7. Tap Wipe cache.
    8. Tap Yes to continue.
    9. Tap Reboot to restart the phone.
  15. SeaRefractor
    Yep, same as the link I'd posted. :) Helps those that don't want to click through. Would be nice if there were a similar support article in the support section on OnePlus. I'd searched for it.
    idbl_fanatic1 likes this.
  16. Gersh
    Eclair Jul 9, 2019
    Gersh , Jul 9, 2019 :
    I am pretty sure my tap to wake worked fine after the update, then hours later stopped. Read nearly every page of this, trying every option, and still can’t get neither single or double tap to work.
  17. G_Radu_TOMA_YKGG
    Eclair Jul 9, 2019
    G_Radu_TOMA_YKGG , Jul 9, 2019 :
    hi! I have a strange situation with this update. if I dial *#800# to activate volte and WiFi calling, evrth works as expected. but dialing *#801# returns nothing! any solution? I'm unable to finish to activate my volte settings.
  18. Staskr
    Cupcake Jul 9, 2019
    G.Reagon and Hitman424 like this.
  19. mikkado
  20. lukaszmario
    Cupcake Jul 9, 2019
    lukaszmario , Jul 9, 2019 :
    just won't to say one plus 7 pro is beast drop my Samsung phone for op7pro the best phone on the planet
    G.Reagon, Shadow0929 and Hitman424 like this.
