453
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. valentinoguerrero11
    Cupcake Jul 10, 2019
  2. ŁukaszDSW
    Donut Jul 10, 2019
    ŁukaszDSW , Jul 10, 2019 :
    Hello, I have not received the latest update in Poland yet. However, I would like to ask if he is planning to add to the dolby atmos EQ? I have many pairs of headphones, Focal listen wireless aptx HD, they play beautifully, however, Hifiman HE400i I do not have a gentle bass and I would like to be able to add it. I suggest multi-band EQ to be able to control from 20Hz to 20kHz as smoothly.
    Very nice, Please, on behalf of everyone who lacks it.
    LukaszRudnicki likes this.
  3. Hitman424
    Gingerbread Jul 10, 2019
    Hitman424 , Jul 10, 2019 :
    brother you need to work for oneplus.. so many of these oneplus pro owners havent even played with the the settings on their phone... first thing i do after every single update is check all my settings everywhere.. make sure some are on and some are off. my pro is working like a charm. have no issues at all.. oneplus is rolling out updates every few weeks... thank God i switched from Samdung and Crapple ... i will never go back to either. keep up the good work helping the helpless..
  4. lucky4u1989
    Donut Jul 10, 2019
  5. LukaszRudnicki
    Eclair Jul 10, 2019
    LukaszRudnicki , Jul 10, 2019 :
    please support this thread:
    https://forums.oneplus.com/threads/no-sound-equalizer-for-the-op7-pro-eu-spec.1051188/
  6. sumit.pawde222
    Froyo Jul 10, 2019
  7. jerryjose1993
    jerryjose1993 , Jul 10, 2019 :
    is anyone experiencing battery drain after this update? previous update I had no issues with battery but now aftwr the update im having battery drain. is anyone else experiencing?
  8. premsonu118
    Froyo Jul 10, 2019
  9. Reetej Kumar khadka
  10. saireddyy
    saireddyy , Jul 10, 2019 :
    Try it now.. It's working
    KeepTransisting likes this.
  11. hoplee
    Donut Jul 10, 2019
  12. David Turney
    David Turney , Jul 10, 2019 :
    jerryjose1993
    No issues here. sorry for the late edit but I've never done this before I was trying to figure out how to do it. anyway here's the current state of my battery after the update.
  13. saireddyy
    Nope... No draining issue... It's perfect and auto brightness sensor is working well now
  14. KingMylo
    KingMylo , Jul 10, 2019 :
    Can someone please help me!!! I sent a few pics to my friend and now it says it reached its limit. How do I solve this problem?????
  15. Immi1988
    Froyo Jul 10, 2019
  16. G_El_Hadj_Chitou_zagD
    Eclair Jul 10, 2019
    G_El_Hadj_Chitou_zagD , Jul 10, 2019 :
    Wow may I see the apps you use?
  17. kaumilbhavsar
    Donut Jul 10, 2019
  18. MEERA MOHANDAS
    Donut Jul 10, 2019
    MEERA MOHANDAS , Jul 10, 2019 :
    While I wait for an update... I would first like to give my kudos to you guys for being so interactive and responsive. Doesn't look like it's a common issue since I don't see any reports here but I have been facing issues with my mic since the last few days. the person on the other end of the call can't hear me if I speak over the handset , whereas over the speaker phone the voice is clear.
    Since my phone is new and under warranty I took it to the service centre here and they too couldn't figure out what the issue was. They ended up changing the mother board and few other parts.
    The Result: The phone has become a little sluggish, fingerprint response is not as efficient and it's overall lost its newness ( yes i consider my two month old phone to be new..) what's worse...the problem isn't fixed..[e]1f612[/e]....I have to take my phone back there again...No idea what else will they do... should I just ask for a replacement? since changing the main component didn't rectify the issue.
  19. Ippolito1971
    Honeycomb Jul 10, 2019
    Ippolito1971 , Jul 10, 2019 :
    fantastic work on this update. camera is vastly improved and IMO better than the pixel camera in most scenarios. Night mode is far better, colors more realistic, and lighting very accurate. First battery cycle without any modifications to software is great running with 90hz refresh and QHD display setting
    jquest71 likes this.
  20. David Turney
    this is all my apps at this time, I have not added all that many. I have learned over the years to add apps slowly and see what each one does to my phone before I add another one.
    also I have automatic screen brightness turned off and my screen is set somewhere around 25% brightness. I have also turned off animations, things seem to load a bit quicker that way. everything else is pretty normal.
