453
OxygenOS 9.5.10 for OnePlus 7 Pro
  1. FRJerome
    Ice Cream Sandwich Jul 14, 2019
    FRJerome , Jul 14, 2019 :
    So you're telling here that :
    - very few people in India didn't get the update ?
    - you read many posts here
    - you can't update through german VPN
    - you can't update through oxygen updater
    Wow
    You're great !
    I think there are about 35 pages of people from your Region complaining that they didn't get the update yet.
    Gunjan Ft Shady likes this.
  2. FRJerome
    If VPN and oxygen updater don't work well... There is an issue !
  3. Huigiebaby
    Huigiebaby , Jul 14, 2019 :
    As long as there's people like you, there will be bitching. You refuse to read and you are all impatient as fu.k! Very very annoying, you should all have been slapped more during upbringing.
    FRJerome likes this.
  4. V1544629925015
    Gingerbread Jul 14, 2019
    V1544629925015 , Jul 14, 2019 :
    Mate.Do me a favor. Stop playing the sheriff here and live your life...
    There is an option called "Zen Mode"
    Use it.
  5. G_Srinadh_123_IEFZ
    Cupcake Jul 14, 2019
  6. V1544629925015
    Yep that's the whole point....
    Zen Mode bro.. Zen Mode.
  7. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 14, 2019
    Swejuggalo , Jul 14, 2019 :
    If vpn does not work it might be a that a update limit has been reached depending how they control the rollout phases.
    Oxygen updater should always work though. It should give you instructions within the app.
    Saikrishna.sk7 likes this.
  8. Saikrishnask7
    Saikrishnask7 , Jul 14, 2019 :
    Thanks mate
    V1544629925015 likes this.
  9. Pervyzz
  10. Pervyzz
  11. V1544629925015
    You must first learn something about people.
    There are only two types of people ...Good and bad but you've invented the third kind ....A lonely jerk.
    Enjoy your life and don't forget... Zen Mode.
  12. Nhas81
    Eclair Jul 14, 2019
    Nhas81 , Jul 14, 2019 :
    Caballeros hay un error con la nueva actualización en el flash de la cámara. es débil y no se sincroniza bien cuando haces el Gentlemen there is a bug with the new update in the camera flash. It is weak and does not synchronize well when you take the photo with flash at a medium distance. they improve one thing and make another
  13. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jul 14, 2019
    KeepTransisting , Jul 14, 2019 :
    A staged rollout isn't a delay. They always do staged rollouts unless you're on the beta channel
  14. jomontl
    jomontl , Jul 14, 2019 :
    no sound in slowmotion video recording,pls add this feature,while op5 supports audio in slow mo recording ,why don't we op7 pro users dont have it.title,slowmotion audio feature must be added
  15. FRJerome
    Issue ?
    Posting all the time the same question without reading previous ones isn't an issue ?
    You really think that it's interesting coming here and reading all time long the same thing ?
  16. FRJerome
    So tell us ! I think that it can be interesting
    Why do you want 48mp also in normal mode while it's available in pro mode ?
    I still don't understand
    I think like Sony does that quad bayer helps a lot all novice photographers since it melts 4 pixels in 1 to produce a very good 12mp photo.
    Why should this mode dedicated to non professionnals shoot in 48mp?
    You're getting angry ?
    I'm just asking you a simple question.
    I thought that pro mode was made for professionals ...but maybe i'm wrong
  17. RajeeGovind
    Eclair Jul 14, 2019
    RajeeGovind , Jul 14, 2019 :
    I did that. Still this is the result. There is something wrong with the image processing software. All the pics taken with this camera are way too saturated.
    baggz143 likes this.
  18. V1544629925015
  19. G_Sauravv_H_ulba
    G_Sauravv_H_ulba , Jul 14, 2019 :
    if you are facing such problem than who has even asked you to come ... people will address Thier concern be it single , in hundreds , in thousands, you ignore it and move forward .
    it's not specifically addressed to you , that you are getting frustrated .
    This is Community forum from One Plus , concern directed to One Plus ... put your Zen Mode on .
    Hopefully this helps you out ... if you are mature enough and use brains wisely.
  20. bhavinder001
    bhavinder001 , Jul 14, 2019 :
    Technically I agree with you but holding an update for more than 5 days it but too much. Apple devices are sold in millions as compared to few thousand OP devices
