259
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. Sir_Pool_de_Float_MD
    Eclair Sep 9, 2019
    Sir_Pool_de_Float_MD , Sep 9, 2019 :
    Following the advice a mod left in a closed thread, figured I'd post here regarding the 9.5.13 OTA.
    I'm unlocked, with TWRP and root. So I downloaded the full OTA, and it appeared to flash fine. I flashed it to the active slot, rebooted to the other slot in recovery, and flashed it again. I then flashed TWRP again, Magisk 19.4 Canary, and the custom kernel I was using.
    My phone booted up fine and the software version reflected 9.5.13, but Magisk Manager said I wasn't rooted. However, apps and scripts running as root continued to work. The kernel did not reflect the one I flashed (arter97 w/ f2fs conversation).
    Flashing Magisk again multiple times did not change the root appearance. Magisk Manager itself would pop up messages that it was denied root access. Other apps still worked.
    I ended up downgrading back to 9.5.11 via OTA, and got everything mostly working again. Root access works as expected for all apps, but now I get a notification that there's an update for both Magisk and Magisk Manager, however they both fail to install.
    Any ideas what could be wrong? I'm planning a factory reset when 10 comes out, but want to avoid one before then.
  2. M1564355784284
    Cupcake Sep 10, 2019
  3. B1567776637880
    B1567776637880 , Sep 10, 2019 :
    force what? an update? that's the latest FW for TMO. you would need to Sim unlock and convert to international FW to update to the latest
  4. dubbaYous
    Ice Cream Sandwich Sep 10, 2019
  5. Swejuggalo
    Jelly Bean Sep 10, 2019
    Swejuggalo , Sep 10, 2019 :
    Odd. Maybe the they haven't certified that phone on the carrier side yet.
    The only problem with my carrier is VoLTE/VoWiFi. Other than that they don't really care what phone you use. Free sms/mms/phonecalls and unlimited data within the country no matter the phone you are using.
    No sure what makes Visible so special
  6. dubbaYous
    dubbaYous , Sep 10, 2019 :
    $40 month unlimited without 5 Mbps limitation that I get in my net10.
    Since it is Verizon's prepaid service, it sounds like a better deal than all the other mvno deals around.
  7. Marek_Orovnicky
    Honeycomb Sep 10, 2019
    Marek_Orovnicky , Sep 10, 2019 :
    most probably it is just carrier limited update
  8. DoobieDroidX
    Froyo Sep 10, 2019
    DoobieDroidX , Sep 10, 2019 :
    it's a US carrier update only
  9. dubbaYous
    DoobieDroidX
    it's a US carrier update only​
    I understand I am in US, Verizon has a prepaid service they just recently started up called (as I assume you are aware) visible. This update should have allowed us to be to be able to use such service since 7 Pro can be used on Verizon. I was wanting to get on it since net 10 is unable to get their act together but it says it is not compatible.
    I assume what was stated was correct that Verizon hadn't done the work on their end yet.
  10. DoobieDroidX
    Froyo Sep 10, 2019
    maybe , but you can just download full zip 9.5.13 and manually update it if not had via ota just use local update
  11. D1560965181344
    Gingerbread Sep 10, 2019
  12. matthewhall
    matthewhall , Sep 10, 2019 :
    When are they going to sort out the galary it really sucks the hide function is the worst you can only hide one picture or vid instead of being able to hide a whole album?
  13. DoobieDroidX
    Froyo Sep 10, 2019
  14. dubbaYous
    DoobieDroidX likes this.
  15. DoobieDroidX
    Froyo Sep 10, 2019
    ah see miss understood you , no worries it's prob not active yet there end like you said
    dubbaYous likes this.
  16. dubbaYous
  17. idbl_fanatic1
  18. ZRXINLA
    Donut Sep 10, 2019
    ZRXINLA , Sep 10, 2019 :
    any bug fixes besides the Verizon crap?
  19. dubbaYous
    Ice Cream Sandwich Sep 11, 2019
    dubbaYous , Sep 11, 2019 :
    Nothing that I know of.
  20. patstar5
    Jelly Bean Sep 11, 2019
    patstar5 , Sep 11, 2019 :
    How do you sign up for service with visible, when I enter imei number of Oneplus 7 Pro it says not compatible?
