261
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. Sugan24
    Cupcake Sep 11, 2019
    K1563510596498 likes this.
  2. K1563510596498
    K1563510596498 , Sep 11, 2019 :
    GPS always show low signal or lost signal after update,tried several Navi apps, but all the same using Google maps, the location not accurate at all, the rest apps, can locate the place, when navigate, it stuck at the start place.
    any ideas?
  3. A1559835099326
    Froyo Sep 11, 2019
    A1559835099326 , Sep 11, 2019 :
    sftr vrsn?
  4. K1563510596498
  5. ModLife
    Ice Cream Sandwich Sep 11, 2019
  6. A1559835099326
    Froyo Sep 11, 2019
  7. ModLife
  8. A1559835099326
    Froyo Sep 11, 2019
    the touch sensitivity is soo fast that some time i put my finger above the display it closer to the screen but not touch the screen but the touch action done.any one notice that?
  9. D1560965181344
    Gingerbread Sep 11, 2019
  10. K1563510596498
    it is a sample route, the dot acting like a ghost, and sometimes it does not move.
    Georgeoneplus7pro likes this.
  11. K1563510596498
  12. Swejuggalo
    Jelly Bean Sep 11, 2019
  13. Swejuggalo
    Swejuggalo , Sep 11, 2019 :
    Seems like a local update for Verizon/US phones
  14. K1563510596498
  15. Swejuggalo
    Google has something called Fused. It's a combination of GPS and mobile network localisation that is supposed to give good enough location with minimum battery drain.
    You can switch between them this way. Click somewhere so you see the 3 lines.
    Click on that (hamburger menu it's called perhaps?)
    Switch between Fused and GPS (device only) somewhere outside with a good line of sight for maximum possibility of GPS signal. If it fails to get a lock on any GPS in any of the states then I would visit a service center. Possible check if something got messed up at some point by doing a factory reset (but chances are slim). Most possible to be a hardware issue.
  16. Shajahankm
  17. Swejuggalo
  18. Nic2112
    Honeycomb Sep 11, 2019
    Nic2112 , Sep 11, 2019 :
    Has anyone ran into a problem where the "Complete your setup" notification comes up even after you completed the setup multiple times?
    Phone will tell me to connect to a wifi (I already am) and say there are app updates. I open the notification and the phone just stayed there, nothing happens.
    Shajahankm likes this.
  19. Georgeoneplus7pro
  20. Georgeoneplus7pro
    Georgeoneplus7pro , Sep 11, 2019 :
    OnePlus 7 Pro has GPS accuracy issues. Compare this to a Samsung, Xiaomi, Huawei, etc. phone and you will see the huge difference. Samsung S10 + uses 55/60 satellites and is not dual band.
