263
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. Tim628
    Eclair Aug 6, 2019
    Tim628 , Aug 6, 2019 :
    When somebody spends €700 on a phone it expects to work out right out of the box without any third party software tweaks and besides gcam works wonders with pixel phones this is why i picked the p30 pro instead
    V3X11 and M1560391326310 like this.
  2. A1560648267550
    Gingerbread Aug 6, 2019
    A1560648267550 , Aug 6, 2019 :
    Glad you picked a different phone, hope you don't install gcam on p30
  3. G1564351194108
    Eclair Aug 6, 2019
    G1564351194108 , Aug 6, 2019 :
    I wish TMobile would update... I tried to change it to the international phone but drivers don't download
  4. A1560648267550
    same thing happened to me I ended up installing the Qualcomm drivers and updating the driver certificate with the cab file from xda. After that it worked
  5. G1564351194108
    Eclair Aug 6, 2019
    where do I find those do you have a link with instructions?
  6. A1560648267550
    G1564351194108
    where do I find those do you have a link with instructions?​
    xda has a guide on how to convert to international rom, the cab file and how to install is around page 86 or 87 if I remember correctly. As for the Qualcomm drivers I just googled it and updated to the most current. What i would do is :
    Install Qualcomm drivers
    Update certificate with cab file on xda
    connect your phone to the laptop and install the OnePlus drivers from your phones drive
    After that follow the instructions for converting, took me forever cause the laptop wouldn't recognize the phone and pull up any coms, this method actually worked
    G1564351194108 likes this.
  7. G1564351194108
    Eclair Aug 6, 2019
    do I install them from my phone or phone hooked to laptop
  8. A1560648267550
    for the OnePlus driver when you connect your phone an option will come up in the file explorer to run OnePlus drivers you run the exe and follow the steps.
    the cab file and Qualcomm drivers are done from the laptop, oh and to update the Qualcomm driver you have to use Windows device manager and unzip the cab file to the same folder you put the msm tool and all files for conversion
  9. G1564351194108
    Eclair Aug 6, 2019
  10. A1560648267550
    you'll hook the phone up when you do the upgrade, if you enter the special update mode and your phone doesn't connect disconnect and try again. if your phone doesn't start by just holding the power button hold up and the power button until the phone vibrates it'll start back up. so you won't brick your phone with this method
  11. A1560648267550
    When I first did it I got the 9.5.10 update then I used oxygen updater to get 9.5.11
  12. staygold1gr
    staygold1gr , Aug 6, 2019 :
    scrolling has become too sensitive, I scroll only a little down on IG and it goes 15 feeds down in half a second before I can read anything
    V3X11 likes this.
  13. idbl_fanatic1
    Ice Cream Sandwich Aug 6, 2019
    idbl_fanatic1 , Aug 6, 2019 :
    Don't "Flick".................scroll
  14. Udayan_Dua
    Donut Aug 6, 2019
    Udayan_Dua , Aug 6, 2019 :
    Brother, I think OP shouldn't have launched the phone with such flaws. Increasing prices and launching half baked phones won't do the company any good.
    M1560391326310 likes this.
  15. ROHINI25
    Eclair Aug 6, 2019
    W1541536202739 likes this.
  16. Mylesocheltree
    Cupcake Aug 6, 2019
  17. G1564351194108
    Eclair Aug 6, 2019
    non. change your phone to the international version. xda has a thread on how
  18. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 6, 2019
    Swejuggalo , Aug 6, 2019 :
    Usually around 2 weeks after official release. Sometimes even later.
  19. G1564351194108
    Eclair Aug 6, 2019
    it's been longer than a few weeks
  20. V1529168106709
