263
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. V1529168106709
    Gingerbread Aug 7, 2019
    V1529168106709 , Aug 7, 2019 :
    I don't see any problem with battery. whole day net on, phone calls, whatsapp, netflix, 30 mins of Pubg, Facebook etc etc.
    still 50% left. left home at 8:45 am with 95% charge
    what more to expect from a 90hz screen phone with 70% brightness level and QHD+ display
  2. MangoDogi
    Honeycomb Aug 7, 2019
    MangoDogi , Aug 7, 2019 :
    Hi! have you tried with another (surely working) sim-card? problem can be also with card itself. Try also with another sim-slot.
  3. K1564324392378
    Cupcake Aug 7, 2019
    K1564324392378 , Aug 7, 2019 :
    thanks guys, I just recently made the switch from iPhone to Oneplus 7 Pro and I'm in love with my phone and I appreciate your constant updates in keeping your users informed (something I never saw with Apple). Keep up the great work!
    Dirk66 likes this.
  4. iGem
    Cupcake Aug 7, 2019
    iGem , Aug 7, 2019 :
    It's very difficult to pull down the notification bar in game mode. I have to scroll down at least 4-5 times before success pulling the notification bar. Never had this problem before the update. Anyone else has this issue since latest update ?
  5. T1564752796635
    Cupcake Aug 7, 2019
  6. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 7, 2019
    Swejuggalo , Aug 7, 2019 :
    Cpu or battery? For cpu it's not really that bad. What settings do you use? The higher you go the hotter it usually gets
  7. Swejuggalo
    Tried to replicate when running Blades but I can't.
  8. T1564752796635
    Cupcake Aug 7, 2019
  9. Dirk66
    Dirk66 , Aug 7, 2019 :
    I notice it too. my guess about 10% more then normal. normally after work I'm at about 70% and now I'm at 60% and lower.
    danutz_timo likes this.
  10. R3DD
    Cupcake Aug 7, 2019
    R3DD , Aug 7, 2019 :
    how do I intiate this update? mine is still running on 9.5.9. any help would be greatly appreciated:)
    K1564324392378 likes this.
  11. HZ_ND
    HZ_ND , Aug 7, 2019 :
    So you are saying this update literally draining your phone.. Tried stopping apps that drains battery?
  12. HZ_ND
    Go to settings >system>system update
    Search for new update
  13. R3DD
    Cupcake Aug 7, 2019
    I tried that and it says system is up to date.
  14. HZ_ND
    You can use oxygen updater.. Can be found in google playstore. Install it.
  15. Dirk66
    nothing drains the battery in terms of apps. two apps are restricted even before the update. Nothing changed or installed...even disconnected my Skagen hybrid watch from Bluetooth. To me it's the system that uses more battery. Installed all previous updates and usage and battery drain was the same....now I notice it drains battery a bit faster.
    danutz_timo and HZ_ND like this.
  16. R3DD
    Cupcake Aug 7, 2019
    it says my phone is not supported. but if i swipe it gives my phone am option on there. (OnePlus 7 Pro)
  17. HZ_ND
    Apps said your phone not supported by oxygen updater?
  18. R3DD
    Cupcake Aug 7, 2019
    correct
  19. BlitzFix
    Donut Aug 7, 2019
    BlitzFix , Aug 7, 2019 :
    Hi everybody, if I have my OnePlus 7 Pro in my pocket, applications open up. If it strikes me, it's too late. I do not know then, what was changed in the individual applications
  20. HZ_ND
    Then u can use VPN to change country and try use the system update... Or use local upgrade by installing zip file which can be downloaded from the internet
