263
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. idbl_fanatic1
    Ice Cream Sandwich Aug 8, 2019
    idbl_fanatic1 , Aug 8, 2019 :
    Try re-adding your print, mine has no issues at all
    thanoskalk likes this.
  2. Gertjan@
    Honeycomb Aug 8, 2019
    Gertjan@ , Aug 8, 2019 :
    idbl_fanatic1
    Try re-adding your print, mine has no issues at all​
    I already tried it, but it doesn't really work, if the screen has been out for a while then the problem arises that the finger scanner is not working properly, and you have to try many times to unlock
  3. BinGhoula
    Donut Aug 8, 2019
  4. iAmPhilo
    Donut Aug 8, 2019
    iAmPhilo , Aug 8, 2019 :
    Whatever was changed to the surface flinger is terrible. Before on 60hz with .10 it felt so much better, more closer to the 60hz screen with the animation and scrolling. This is so janky like before .10 update.
  5. RAJESH1432
    Cupcake Aug 9, 2019
  6. Tuan anh tran
    Eclair Aug 9, 2019
    Tuan anh tran , Aug 9, 2019 :
    i just got my oneplus 7 pro recently. I noticed that when I go check on the vibration mode, other options showed you preview (how it will vibratw if picked). however, dynamic mode wont show you how it will vibrate when being chose. you can only find out by choosing it then call your oneplus to find out. does it happen to anyone? is it a bug ? i am on 9.5.11
  7. Deactivated User
    Aug 9, 2019
  8. SKRAJPUT
    Cupcake Aug 9, 2019
    SKRAJPUT , Aug 9, 2019 :
    i noticed wierd Rainbow artifacts over the screen when streaming videos on Amazon prime
  9. A1560648267550
    Gingerbread Aug 9, 2019
    A1560648267550 , Aug 9, 2019 :
    Pretty sure that's how dynamic works, it mimics the ringtone I believe
  10. Tuan anh tran
    Eclair Aug 9, 2019
    does it happen to you too? when you click on synamic vibration pattern, it does not do anything right. however, if you click on zzz patern, it does show you how it will vibrate
  11. A1560648267550
    yeah happens to me too, but dynamic works like that cause it needs the ringtone to simulate the vibration...switch the ringtones and call yourself you'll see what I mean
    Tuan anh tran likes this.
  12. Tuan anh tran
    Eclair Aug 9, 2019
    thanks so much .just want to know if it is a glitch or something. I am still deciding if I should keep it or wait for oneplus 7T pro lol
    A1560648267550 likes this.
  13. A1560648267550
    honestly I'm sticking with this phone for awhile, it's been one of my best devices
    Huigiebaby likes this.
  14. akks
    KitKat Aug 9, 2019
    akks , Aug 9, 2019 :
    If you keep waiting for minor things, you will keep on waiting.. after 7T, 8, then 8T... So on.
    If you want an awesome device now, go for 7pro
  15. animaaryan
    Honeycomb Aug 9, 2019
    animaaryan , Aug 9, 2019 :
    Have people bought OnePlus 7 Pro only for camera? I agree there are some pictures that come out little bit off but not every picture I've taken makes me feel stupid. After some post processing it looks really good. And coming again to comparison with other devices, they are launched with specialisation in certain field: Camera, Processing, Battery, Recording, etc.
    OnePlus is providing you with everything in one. Even a OnePlus One in 2019 is way advanced for it's own time. Wait for few more year and people will be still passing positive feedback for OnePlus as a company itself.
    And before anyone says "Oh no, you really don't know about phones" Yes, I'm a little low of knowledge, but I've used every device from Sony Ericsson to Google Pixel and everything in between. Pretty far I'm facing no issues, and I'm clicking photos with light sources easily available. We are not paying this amount only for a DSLR, but for everything you need in your day to day functioning. The best way is to describe OP7 is Jack of all Trades.
  16. W1565281317673
    Cupcake Aug 9, 2019
    W1565281317673 , Aug 9, 2019 :
    For cellular no pushing is required! was visible directly on one plus 6
  17. akks
    KitKat Aug 9, 2019
    Agree. In good daylight OnePlus camera also takes stunning images. But it isn't consistent especially in indoors and low-light situations. Gcam is perfect in almost all situations. So room for improvement is always there for camera department. As per history of Oneplus, they won't improve their camera any further, they can't. Still I'm satisfied very much with the device. For better images I use gcam.
  18. ninja123456
    Jelly Bean Aug 9, 2019
  19. G_Akarsh_Agrawal_ODAV
  20. anusharao
    Eclair Aug 9, 2019
    anusharao , Aug 9, 2019 :
    yep I too faced it maybe twice
