263
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. G_Rishabh_Srivastava_jRl
    Eclair Aug 12, 2019
    G_Rishabh_Srivastava_jRl , Aug 12, 2019 :
    Hey guys! Are you able to locate the Audio Tuner option ? I have noticed it to be missing since the last few updates.
    It was a great feature to control sound output through the earphones.
    thanoskalk likes this.
  2. G_Nihar_Jain_
    Gingerbread Aug 12, 2019
    G_Nihar_Jain_ , Aug 12, 2019 :
    After updating to latest version,camera quality is degraded.
    Too saturated,photo losing colour
    Anyone else facing this issue?
    B1556444984933 and thanoskalk like this.
  3. Satyam Singhal
    Cupcake Aug 12, 2019
    Satyam Singhal , Aug 12, 2019 :
    In OP 7 Pro Battery drain so fast and during charging its taking 90 to 95 minutes through Wrap charging from 0 to 100 % please fix this issue through software update.
  4. Riz157
    Froyo Aug 12, 2019
    Riz157 , Aug 12, 2019 :
    that's unusual
    mind you I've reviewed iPhone X X's and Max, I did find they all lagged. At times delayed between apps
    not sure how bad the delay is on your phone but if it's lagging considerable you may have to return or reset your phone. Must say it's unusual, maybe software issue
  5. akks
    Jelly Bean Aug 12, 2019
    akks , Aug 12, 2019 :
    Latest camera version or firmware version?
    Photo quality indoors look oversaturated in camera version 3.4.25. outdoors, it's good.
    G_Nihar_Jain_ likes this.
  6. H1564945040231
    H1564945040231 , Aug 12, 2019 :
    thank you I am about to do as you advise.
    Ippolito1971 likes this.
  7. H1564945040231
    I am planning to do the reset
  8. Anzor8787
    Anzor8787 , Aug 12, 2019 :
    Молодцы OnePlus. Постоянная поддержка системы.
  9. M1565388808726
    Donut Aug 12, 2019
    M1565388808726 , Aug 12, 2019 :
    I also have this problem. Reddish photo indoor, and too much blurry watercolor effect in faces/hair/heads of people.
  10. G_Nihar_Jain_
    yess, even i am using 3.4.25
    Is it the camera update issue or software?
  11. akks
    Probably camera software issue.
  12. Ippolito1971
    Honeycomb Aug 12, 2019
    Ippolito1971 , Aug 12, 2019 :
    I hope all goes well and you find the outstanding experience many are having. Honestly OnePlus is the best Android experience I have had since starting to use Android. Let me know how things go!
    H1564945040231 likes this.
  13. SRIKKANTH5
  14. akks
    Press and hold on an object seen in the viewfinder
  15. ali19puru
    ali19puru , Aug 12, 2019 :
    m facing heating issue with this phone then it start getting hanged and final turned off the application that i was using like gallery camera and pubg ...i have 8 gb varient ...still facing this issue totally disappointed...
  16. SRIKKANTH5
    SRIKKANTH5 , Aug 12, 2019 :
    doing the same it is showing error like Google keeps stopping
  17. akks
    Try clearing cache or complete storage of Google and lens apps
  18. SRIKKANTH5
    its working after updating Google app [e]1f44d[/e]
  19. Devvfata1ity
    Devvfata1ity , Aug 12, 2019 :
    been benchmarking a bit...the GPU and storage scores are lower after this update...storage actually by quite a lot
  20. roy22322
    roy22322 , Aug 12, 2019 :
    hello i have one plus 7 pro recently bought
    i am facing screen flashing issue in fnatic gaming mode
    when i play pubg in gaming mode.
    screen keeps on flashing . solve the query asap
