231
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. F_Pee_Cee_Ramdingliana_C Donut Aug 13, 2019 at 7:03 AM
    F_Pee_Cee_Ramdingliana_C, Aug 13, 2019 at 7:03 AM :
    So, you're saying that the oxygenos 9.5.10 was the very firmware used by Dxomark while testing the camera of the Oneplus 7 Pro? Then, I've already received 9.5.10 as well as 9.5.11 and I'd very much like test out the camera with Galaxy S10/S10+ or P30 pro/Pixel 3 series.
  2. FRJerome Ice Cream Sandwich Aug 13, 2019 at 7:06 AM
    FRJerome, Aug 13, 2019 at 7:06 AM :
    Imo yes
    But don't forget to read the article of dxomark
    They gave 71/100 in texture
    OnePlus 7 Pro images generally show good detail preservation, with only the very finest details lost in both outdoor and indoor images. In static images (no subject movement), it recorded extremely consistent acutancescores of around 80% under lighting levels between 20 to 1000 lux, so the loss of detail starts to become very noticeable only in very low light. Fractionally more fine detail is present in the iPhone XS Max and Huawei P30 Pro images, which both score very slightly higher than the OnePlus 7 Pro as a result, but you’d really need to “pixel peep” to see any differences among them.
  3. B1556444984933 Cupcake Aug 13, 2019 at 7:07 AM
    B1556444984933, Aug 13, 2019 at 7:07 AM :
    I have the three devices that I commented on and after the last updates the camera was very bad. I know the hardware and lenses are great, but at the moment the photos are bad. Not to mention the flash that doesn't help as much as it should by the way it fires in op7pro. I had op6t and the photos were better from my point of view looking at the op7pro screen. There are other problems also besides the camera.
  4. FRJerome Ice Cream Sandwich Aug 13, 2019 at 7:10 AM
    FRJerome, Aug 13, 2019 at 7:10 AM :
    Then if you have those 3 devices just post the same photos taken with them
    Light
    Less light
    And crop them
    Dxomark did this very well
    This is the only thing to do to honestly compare...
  5. FRJerome Ice Cream Sandwich Aug 13, 2019 at 7:11 AM
    B1556444984933 likes this.
  6. Satyam Singhal Cupcake Aug 13, 2019 at 7:16 AM
    Satyam Singhal, Aug 13, 2019 at 7:16 AM :
    I am not here to making problem up just sharing my problem which i faced if you have solution let me know how to fix the battery drain problem.
  7. B1556444984933 Cupcake Aug 13, 2019 at 7:20 AM
    B1556444984933, Aug 13, 2019 at 7:20 AM :
    I'll do the photos in the morning and post. Estou sinceramente pensando em vender meu op7pro. Isso não me deixou satisfeito. Estou apaixonado por fotos e não fiquei satisfeito com a câmera op7pro.
    FRJerome likes this.
  8. FRJerome Ice Cream Sandwich Aug 13, 2019 at 7:22 AM
    FRJerome, Aug 13, 2019 at 7:22 AM :
    Every case is peculiar
    You probably installed an app that drains your battery
    Or you have settings that are agressive
    If you want to check it's very easy
    Back to the beginning
    Full erase
    Use it 2 days as a new phone
    And install your apps 1 by 1
  9. FRJerome Ice Cream Sandwich Aug 13, 2019 at 7:22 AM
    That would be great
  10. B1556444984933 Cupcake Aug 13, 2019 at 7:25 AM
    B1556444984933, Aug 13, 2019 at 7:25 AM :
    I am honestly thinking selling my op7pro. It didn't make me satisfied. I'm in love with photos and was not satisfied with the op7pro camera.
  11. FRJerome Ice Cream Sandwich Aug 13, 2019 at 7:39 AM
  12. FRJerome Ice Cream Sandwich Aug 13, 2019 at 8:03 AM
    FRJerome, Aug 13, 2019 at 8:03 AM :
    Did anyone install gcam 6.2 ?
    Can you take 5 times same picture with gcam and normal app?
    And compare speed ?
    For me with sun
    1/1200 normal app
    440/1000000 gcam
    Someone can explain ?
  13. FRJerome Ice Cream Sandwich Aug 13, 2019 at 8:12 AM
    FRJerome, Aug 13, 2019 at 8:12 AM :
    Tested inside
    Same photo
    Same light
    It's just funny
    Gcam is 2x faster
    1/100
    Normal
    1/50
    ISO is appx 800-900 for gcam
    500 for normal
    Photos with gcam look a bit darker
    But are so sharper !
    It's just crazy
    There is a settings issue from OP
    I think they made mistakes on this version
    1/50 in low light conditions is not enough
    It's normal it gives blurred images
    And they had a post treatment to correct it... Washes détails...
  14. M1543331582167 Cupcake Aug 13, 2019 at 8:14 AM
    M1543331582167, Aug 13, 2019 at 8:14 AM :
    I have a oneplus 7 pro that has hydrogen9.5.9.gm21 to oxygen
    error:
    Local upgrade
    The version of your selected pack- age is lower than that of the current system. To avoid booting up failure, downgrading is not allowed.
  15. FRJerome Ice Cream Sandwich Aug 13, 2019 at 8:28 AM
    FRJerome, Aug 13, 2019 at 8:28 AM :
    Pretty enjoyed my tests Yesterday evening and this morning ..
    So one question one plus : HOW CAN WE TAKE CORRECT PHOTOS WITH LOW LIGHT CONDITIONS WITH SUCH SMALL SPEED???
    Photos are taken with almost 1sec speed!
    1/17... 1/25...
    It's just impossible to be just a bit sharp !!!
    Gcam looks better ?
    Oh they never shoot under 1/100 !
    What a coincidence !
  16. Lokesh Chilukoti Cupcake Aug 13, 2019 at 9:54 AM
  17. Swejuggalo Ice Cream Sandwich Aug 13, 2019 at 11:45 AM
    Swejuggalo, Aug 13, 2019 at 11:45 AM :
    https://otafsg1.h2os.com/patch/amaz...n_21.O.14_OTA_014_all_1907281611_7972d376.zip
    This would be the file you need. 9.5.11. You could also download it with Oxygen Updater. All you need to do is to select international full update om settings.
    If you download from the link verify the integrity of the file manually.
    Md5: a9be12bf12bc34cca79c93956e0b241a
  18. dhopmans Gingerbread Aug 13, 2019 at 11:54 AM
    dhopmans, Aug 13, 2019 at 11:54 AM :
    Then you should buy a really good camera! Good day and have a nice one on another forum.
  19. Swejuggalo Ice Cream Sandwich Aug 13, 2019 at 11:55 AM
    Swejuggalo, Aug 13, 2019 at 11:55 AM :
    FRJerome
    1/17... 1/25...
    Gcam looks better ?
    What a coincidence !​
    Opps... Quoted the wrong person again [e]1f609[/e]
    Don't really know. Too many factors make a differance.
    Yesterday I got 6.5h with 41% left. When I'm at work it drains faster due to bad wifi and bad mobile reception.
    So in my usage the differance in low and high SOT could be 4-5h or even more depending on situation, where I am, what I do, how much sun and so on...
    I hunt down background drain and block bad wakelocks to maximize battery life. The rest is hard to control.
  20. dhopmans Gingerbread Aug 13, 2019 at 11:55 AM
    dhopmans, Aug 13, 2019 at 11:55 AM :
    That depends on what apps you have installed. So no one has the same settings and apps. It's all different for everybody.
