263
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. Vishven Parekh
    Cupcake Aug 14, 2019
    Vishven Parekh , Aug 14, 2019 :
    the Dialing screen is showing later after the ringtone rings. *** well as when we cut the phone it doesn't get cut it cuts after several seconds. phone is bit malfunctioning.kindly resolve this issues in new update asap
  2. deypratim
    Eclair Aug 14, 2019
    deypratim , Aug 14, 2019 :
    In my case, wifi, data, bluetooth,location.. all are ON, battery saver is also ON..battery drains 4%-5% for 5 hours at night.
  3. david678
  4. Swejuggalo
    KitKat Aug 14, 2019
    Swejuggalo , Aug 14, 2019 :
    0.3-0.4% per hour with wifi, mobile and location always on. Sleep standby optimization on.
    Naptime with excluding rules and some tweaks. Not rooted.
  5. Swejuggalo
    KitKat Aug 14, 2019
    Hopefully soon. Or if they hold on it until next update. They seem to work in mysterious ways
    H1561960043803 likes this.
  6. DarKAvaloN
  7. DarKAvaloN
  8. H1561960043803
    Ice Cream Sandwich Aug 14, 2019
    H1561960043803 , Aug 14, 2019 :
    I got tired of waiting, and switched to the international version. was super simple, and I stressed out about doing it for nothing lol. now I just need to take the leap to android Q beta lol. totally worth it though. took about 10 minutes from download to setup completion.
    ronnyhawks likes this.
  9. F1563043414772
    F1563043414772 , Aug 14, 2019 :
    VOLTE option missing after putting new sim card but if the sim card i put in other mobile it VOLTE works. please give some solution. thanks in advance
  10. Struna
    Froyo Aug 14, 2019
    Struna , Aug 14, 2019 :
    0.3-0.4% per hour? Really?
  11. Swejuggalo
    KitKat Aug 14, 2019
    Yepp. Thanks to my tweaks. http://bit.ly/2ZzdsP8
    I have some shitty apps that drains like Life360 but I disabled wakelocks for that app and a few others (Life360 seems to work as badly as normal more or less anyway [e]1f609[/e]) . Also use Naptime with exclusions like Life360 and other apps that I want active when I don't use the phone. Sleep battery optimization is on too.
  12. deypratim
    Eclair Aug 14, 2019
    sorry typing mistake, 3 to 4 percent for 5 hour
    sergi71bdn and Struna like this.
  13. Andrés Cortés Cantador
    Andrés Cortés Cantador , Aug 14, 2019 :
    Por favor OnePlus, la pantalla ambiente no funciona bien al ser tan sensible en la opción "levantar para despertar", simplemente moviendo un poco el móvil se enciende la pantalla ambiente. Deberías tener que levantar el móvil como para verlo para que se encendiese ya que está continuamente encendido en el bolsillo o si lo llevas en la mano, vibrando al no reconocer la huella.
    sergi71bdn likes this.
  14. H1561960043803
    um.. if I had to guess, something is wrong with your ambient something
  15. Weirdpepperguy
    Gingerbread Aug 14, 2019
    Weirdpepperguy , Aug 14, 2019 :
    Nobody knows. They never give us any love
  16. F1560000358431
  17. arefinkaosar
    Donut Aug 14, 2019
    arefinkaosar , Aug 14, 2019 :
    have anyone faced any issue with file manager? files are disappearing if i rename it[e]1f623[/e]
    Z1558843799122 likes this.
  18. idbl_fanatic1
    idbl_fanatic1 , Aug 14, 2019 :
    I just renamed a file with no issue
  19. arefinkaosar
    Donut Aug 14, 2019
    not every time..some files i had to rename and it happened 20-30% times
  20. Jimmyostrom
    Jimmyostrom , Aug 14, 2019 :
    okey thnx
