263
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. appleak.ayw
    Cupcake Aug 14, 2019
  2. PigPecs
  3. F1558745177939
    Donut Aug 15, 2019
    F1558745177939 , Aug 15, 2019 :
    we've is this going to be released. I have heard of other up dates. to the 7 pro. but since having the phone only received one update in July. I'm still running 9.5.9
  4. David Turney
    Gingerbread Aug 15, 2019
    David Turney , Aug 15, 2019 :
    is that T Mobile?
  5. F1558745177939
    Donut Aug 15, 2019
  6. David Turney
    T Mobile is responsible for your update. Best guess is within the next couple of weeks.
    BobJax likes this.
  7. F1558745177939
    Donut Aug 15, 2019
    I've heard there was camera up dates. I have seen no differences at all in mine. I don't get it
  8. Ven96
    Froyo Aug 15, 2019
    Ven96 , Aug 15, 2019 :
    Only from 9.5.8 to 9.5.11 there should be a difference in camera quality. If you updated from 9.5.9 to 9.5.11 there will be no difference, since 9.5.11 is a simple remake of 9.5.9 because of its bugs.
  9. JoseReyes69
    JoseReyes69 , Aug 15, 2019 :
    It's anyone having issues with Chrome and Google while on LTE. Working fine over Wifi but not over LTE.
  10. akks
    Jelly Bean Aug 15, 2019
    akks , Aug 15, 2019 :
    No. Network issues?
  11. akks
    Camera version is upgraded in 9.5.11
  12. JoseReyes69
    all other apps work fine. it's just Google and chrome
  13. akks
    Tried clearing the data of those apps?
  14. JoseReyes69
    Nothing I did worked so I ended up doing a complete wipe. Is all good now.
  15. mayurshobhavat
    Cupcake Aug 15, 2019
  16. Swejuggalo
    KitKat Aug 15, 2019
    Swejuggalo , Aug 15, 2019 :
    Any specific situation? Could be temporary. Leave it plugged in a night an see if the issue is gone the next day.
    The other things you can do is to check both areas of battery stats and show us what is draining battery and causing the heat.
  17. G_sumit_pal_singh_Chawla
    G_sumit_pal_singh_Chawla , Aug 15, 2019 :
    hi...I m new to one plus community...I recently purchased one plus 7 pro...the build number is oxygen os 9.5.4...i got an update 9.5.11 of around 400 MB...I have downloaded it but not installed it...do I need to download the previous updates to improve camera performance or will this update include all previous ones... thanks in advance...
  18. Swejuggalo
    KitKat Aug 15, 2019
    No. Newest version includes everything. If you downloaded from the normal built-in updater just go ahead an install
  19. G_sumit_pal_singh_Chawla
    thanks...
  20. Lg428
    Froyo Aug 15, 2019
    Lg428 , Aug 15, 2019 :
    Anyone having problems with watching videos on the 7 Pro? Cause I've noticed that when watching video on YouTube and Netflix whenever a YouTuber or actor is in a dark environment the 7 pro gets covered with grey pixels. Like the phone does not process the dark background like it should be. it's so bad and annoying to the point where I stopped watching Strangers things on Netflix. Anyone else have this problem?‍♂️
