261
OxygenOS 9.5.11 for OnePlus 7 Pro
  1. G1564351194108
    Eclair Aug 19, 2019
    G1564351194108 , Aug 19, 2019 :
    ok I'll give it another shot after work
  2. A1560648267550
    Froyo Aug 19, 2019
    G1564351194108 likes this.
  3. L1565978665702
    Cupcake Aug 19, 2019
  4. Chhunhour_Kh
    Froyo Aug 19, 2019
    G_Pol_Bonastre_rHEG likes this.
  5. G_Sridhar_Bheeman_lJRH
    Eclair Aug 19, 2019
    G_Sridhar_Bheeman_lJRH , Aug 19, 2019 :
    My screen glitches after the update, it happens rarely. I tried to record the glitch and play it. It looks like the display is fine and looks like a software bug.
  6. nosvasedis
    Eclair Aug 19, 2019
  7. R_d_M
    Froyo Aug 19, 2019
    nosvasedis likes this.
  8. nosvasedis
    Eclair Aug 19, 2019
    nosvasedis , Aug 19, 2019 :
    Do we have any fix?? or do we have to wait for the next update?
  9. Ashitabh.nayak
  10. R_d_M
    Froyo Aug 19, 2019
    R_d_M , Aug 19, 2019 :
    No fix , android Q beta was much better on battery but the delayed notifications pushed me back to this build...
    Lets hope next update comes fast.
    already 20 days so...
  11. unicornZ
    Gingerbread Aug 19, 2019
    unicornZ , Aug 19, 2019 :
    For me battery backup is incredible. Two full days without need of charging. Resolution QHD, refresh rate 90hz
  12. R_d_M
    Froyo Aug 19, 2019
  13. unicornZ
    Even with heavy usage it lasts a day. 9hrs SOT is great
  14. R_d_M
    Froyo Aug 19, 2019
  15. nosvasedis
    Eclair Aug 19, 2019
    how can you manage this kind of battery life? I've never gotten more than 5 hours SOT and I have the device for two weeks already. I also have most apps like you and nothing strange. NFC On, Adaptive resolution, 90HZ, VOLTE on, VOWIFI off, wifi mostly, moderate usage of data, Bluetooth mostly off unless I listen through the Bullets 2... So why this huge difference?
  16. Swejuggalo
    Jelly Bean Aug 19, 2019
    Swejuggalo , Aug 19, 2019 :
    Several things matter. What apps that is installed and some options like RAM boost. How terrible Google play services act for example (idle drain).
    2 days ago or so I had 6.5h and 41% left.
    I have RAM boost of and wifi/mobile/location always on. Naptime installed with a few exclusions. A few wakelocks ignored and stuff.
    Tried to collect some tips in a guide. Not everything is helps for everyone but knowing what happens after a change helps a lot.
    All tweaks is done without root.
    http://bit.ly/2ZzdsP8
  17. David Turney
    David Turney , Aug 19, 2019 :
    why do you believe ram boost off is best for battery
  18. Swejuggalo
    In my case it seems to do better without it. Having it on can result in some unwanted activity that drains more than doing good. Best is to try what fits you the best. The results is not the same for everyone.
  19. David Turney
    ok, thanks I will try it off then on,. no other changes while I do that
  20. Swejuggalo
    You might need to reboot to get the best effect.
    You probably know after a few days if and by how much it make a differance.
