236
OxygenOS 9.5.4/9.5.5 for OnePlus 7 Pro Global/EU [9.5.6 for the US]
  1. surendra91
    Honeycomb May 26, 2019
  2. elanglois
    Lollipop May 26, 2019
    elanglois , May 26, 2019 :
    The camera will work, image processing will work. Google Lens integration will need libraries to integrate the viewfinder image, which will be part of the HAL, no the camera or its processing.
    Oddly enough. My OP7 Camera will pick up the QR code for my WiFi, but manually opening Google Assistant and turning on Google Lens doesn't work. Google Assistant won't see the QR code. That's really weird.
    But ... if you want CAMERA improvements, you can download the APK.
    Hitman424 likes this.
  3. JelleZon
    OnePlus Accessory Tester May 26, 2019
  4. Rohit Mann
    Cupcake May 26, 2019
    Rohit Mann , May 26, 2019 :
    I have observed a weird bug after the update changing dpi from the developer settings is not changing the dpi across multiple applications like facebook, instagram, outlook, twitter etc. Their dpi level is different as compared to phones dpi level. Please fix it.
    smeagel likes this.
  5. elanglois
    LOL. This is what we hear EVERY phone launch. Then Oneplus will "fix" the watercolor and people complain that its grainy, especially when they zoom in on someone's nose with the front camera in low-light. Then they fix it again .... grainy or watercolor ... those are the options unless you install GCAM. The quality looks good to me for a built-in camera
  6. bala_gamer
    Donut May 26, 2019
    bala_gamer , May 26, 2019 :
    much better pics with low light in this new update. above pics in comparison with the latest gcam out there with somewhat tweaked saturation levels ( people following gcam development would know by now that the saturation level on gcam is yet to be fixed)
  7. Iamrohit.07
    Iamrohit.07 , May 26, 2019 :
    please add custom fonts support sir. @Manu J. the current two fonts are not good. at least please add "monotype ttf support." because they made the official OnePlus slate^TM FONT.
    Scottspa74, Hitman424 and Nuiza11 like this.
  8. Yashvendra_Singh_Raghav
    Ice Cream Sandwich May 26, 2019
    Yashvendra_Singh_Raghav , May 26, 2019 :
    yes bro totally agreed,
    [e]1f44d[/e].
    i m having iphone xs, op5, recently purchased op7 pro.
    TheRealGamer likes this.
  9. subhankar_dey
    Froyo May 26, 2019
  10. cas8180
    cas8180 , May 26, 2019 :
    yup these forum's. thanks captain obvious.
    gmaria1987 likes this.
  11. Thetatif
    Eclair May 26, 2019
    Thetatif , May 26, 2019 :
    Is this Indian forum? Cause I see several posts mentioning number without mentioning the currency.
  12. chanakya
    Froyo May 26, 2019
    chanakya , May 26, 2019 :
    is anyone having problem with display resolution after the display. smallest width in developer option getting rest to 470 and text in play store is really huge
  13. Yashvendra_Singh_Raghav
    ya sir, i don't exactly know, but little bit overview i know not i depth.
  14. pruthisith
    Donut May 26, 2019
  15. marq9
    marq9 , May 26, 2019 :
    Can you swipe left/right in dialer app to switch between e.g. calls history and contacts? It works this way on older OP phones with Pie installed, but sadly not on OP7 Pro.
  16. elanglois
    If two cameras are side by side, then the distance between pixels will vary with the distance from the lens. This is especially true when using a camera with a different focal length.
    So, only 1 camera provides the image. Another camera is used ONLY to determine the distance of each pixel. The distance is used to determine how much blur to place on the image.
    The images are not combined and which camera is used as the secondary is irrelevant
  17. Bombhills
    Froyo May 26, 2019
    Bombhills , May 26, 2019 :
    Yes! It's driving me crazy, at lease they should make any announcement about it!
    Dirk66 and Hitman424 like this.
  18. elanglois
    I've not had any such issue. More than likely, it will be a ground issue. Oneplus One had the same problem
  19. Jitender Rajput
    Eclair May 26, 2019
    Jitender Rajput , May 26, 2019 :
    hope to receive a better update to make Camera more stunning and to do fabulous job.. hopw for worth it Improvement for Tripple camera
  20. Bullo Oka
    Bullo Oka , May 26, 2019 :
    Camera is the weakest point of One plus device, it always was and I believe it always will be. but doesn't matter to me, I don't use it as photography device.
    A suggestion from my view, instead of upgrading to every new Android device, save those money and look for a entry range DSLR. you won't regret that decision. OnePlus devices are powerfull enough to last atleast 3 years, my preference are 4 years minimum.
    ***No offence to those who collect every OnePlus device. it all defends on users choice.
