236
OxygenOS 9.5.4/9.5.5 for OnePlus 7 Pro Global/EU [9.5.6 for the US]
  1. elanglois
    Lollipop Jun 6, 2019
    elanglois , Jun 6, 2019 :
    ambient mode has nothing to do with how bright your screen is. what are you talkin about?
  2. IwantOneplus!
    Ice Cream Sandwich Jun 6, 2019
    IwantOneplus! , Jun 6, 2019 :
    No why would I? I am not going to compromise. I take a shot of my family. My daughter pic turns out great and i want to zoom in, crop and save that. Then what? I deal with the blur and grain? this is all in proper light. no low light here... all my shots blur and grain. I am certain this is fixable and they should fix this.
    In the message from last update they stated that they listen to users feedback and improve. I thought this was just main lens but its all across. I can say it's definitely improve form last version. a bit more clear but not perfect. they just need to clean it up a bit add sharpness.
    tobias14 likes this.
  3. elanglois
    Stop clearing caches, leave phone plugged in at night!
  4. elanglois
    report in feedback this is a public forum not the bug reporting section
  5. IwantOneplus!
    Good point! I am sure they have a bright crew. We don't know what's going on behind the scenes. In time updates should roll out and hope to god camera improves. I am going to Europe and will be shooting with Oneplus 7pro. Wish they came out with another OTA update before i leave the 8th of June lol.
  6. IwantOneplus!
    Already done. Thanks for informing.
  7. MR.BEN312
    Honeycomb Jun 6, 2019
    Predict23 likes this.
  8. mustafa4ever89
    Froyo Jun 6, 2019
    mustafa4ever89 , Jun 6, 2019 :
    Battery life has suffered significantly since the 9.5.6 update in the US. I was getting around 7hrs screen on time on 9.5.3 and now with similar usage I average 4hrs. The drain is more on both use and standby since the update.
    Portrait mode in the camera needs alot of work. It's too zoomed in and pictures turn out really grainy even in good lighting. Compare that to the Pixel 3 portrait mode and you can tell the difference is significant.
    IwantOneplus! likes this.
  9. elanglois
    More than likely, its not the update but some new app you've installed. It's almost always an app
    Vector likes this.
  10. Spelt
    Spelt , Jun 6, 2019 :
    You are right it is adaptive brightness on my phone that is having the problems. Its supposed to be adaptive, well its not very adaptive on my phone. I had to actually go into the settings to see what it was. What i thought it was, well its not. In low light the brightness stays really low as well. Too low to be usable.
    Deactivated User and MR.BEN312 like this.
  11. V3X11
    Froyo Jun 6, 2019
    V3X11 , Jun 6, 2019 :
    Well I'm having exactly the same problem with adaptive brightness...this needs to be fixed.
  12. elanglois
    Pie learns. Just manually adjust it for awhile with auto mode on and it should learn how you want it
    MR.BEN312 likes this.
  13. elanglois
    See post above. Nothing needs to be fixed
  14. V3X11
    Froyo Jun 6, 2019
    I'm using it that way but as I remember on my OP6T I didn't have to do this type of manually adjusting of brightness and the phone was also on Pie.
  15. J_Alarcon
    Donut Jun 6, 2019
    J_Alarcon , Jun 6, 2019 :
    when will this update be available for TMobile one plus users? I have yet to get the update
  16. karasani harsha
    Donut Jun 6, 2019
  17. akks
    KitKat Jun 6, 2019
  18. Manisha_piplani_6268
    Cupcake Jun 6, 2019
    Manisha_piplani_6268 , Jun 6, 2019 :
    same issue
  19. Manisha_piplani_6268
    Cupcake Jun 6, 2019
  20. G_Brandon_Clark_kPTj
    Gingerbread Jun 6, 2019
