236
OxygenOS 9.5.4/9.5.5 for OnePlus 7 Pro Global/EU [9.5.6 for the US]
  1. 7 Delusions
    Froyo Jun 6, 2019
    7 Delusions , Jun 6, 2019 :
    I already have it. No update for me. I think it is because I've updated from 9.5.5 EU to 9.5.6 US even tho they are mostly the same thing.
    If someone is willing to share the update file it would be much appreciated!
  2. 7 Delusions
    Froyo Jun 6, 2019
    MR.BEN312 likes this.
  3. G1558842425747
    Eclair Jun 6, 2019
    G1558842425747 , Jun 6, 2019 :
    wow even with this 30w warp charger?
  4. MR.BEN312
    Honeycomb Jun 6, 2019
    MR.BEN312 , Jun 6, 2019 :
    this is a warp charge you don't have to charge it over night. That's another great thing about this phone...the battery is the best today ...NEVER SETTLE
  5. G.Reagon
    Froyo Jun 7, 2019
    G.Reagon , Jun 7, 2019 :
    no, you should never charge any smartphone over night, especially a phone like the 7 Pro that can be fully charged in about an hour. do a Google search on "how to take care of a smartphone battery". a ton of websites will tell you to never charge them to 100% and never let them reach 0%.
    charge the phone to 85% then let it drain to about 30%, then charge it back up to 85%, over and over. a full charge or full drain stresses the battery a d will shorten it's life span.
  6. Spelt
    Ice Cream Sandwich Jun 7, 2019
    Spelt , Jun 7, 2019 :
    Ok I will give it a shot for a week or two. That should be long enough to find out if it will adapt the brightness level.
    Update: I set it for auto-brightness leveling and ran it though some on/off cycles at the brightness level I use for a bit just to see what it would do. At first it was inconsistent but the more cycles I put it through it more consistent it seemed to get. So far pretty good. I think I was still negatively influenced by the phones old behavior before the latest OTA's. The phones current behavior is different than what it was previously. Now I need to change my own thoughts toward the phone with new expectations in mind. LOL I can learn, I am not totally set.
  7. Spelt
    Like adaptive brightness the battery also appears to have adaptive tech built into it also. With OP7P I have the battery has slowly been getting better on the length of time it lasts. Its not something that just happens over night. The length of on screen time seems to take several weeks to develop. This adaptive behavior for android 9 is different than previous versions of android such as 8. Definitely something new for me since this is my first exposure to android 9. New phone new android version even though android 9 has been out for a while. I am coming from an OP3 which doesn't have android 9 yet.
    G.Reagon likes this.
  8. Yashvendra_Singh_Raghav
    Yashvendra_Singh_Raghav , Jun 7, 2019 :
    install this latest cemera update with bunch of improvements.
    oos 9.5.6/7
    Changelog:
    Camera
    Improved overall contrast and color performance
    Improved white balance consistency of triple camera
    Improved accuracy and stability of auto focusing
    Fixed issue of greenish tone in some low light scenes
    Fixed issue of noise in some HDR scenes
    Improved contrast and color saturation of ultra wide
    Improved clarity and noise reduction in low light scene of ultra wide
    Improved clarity and noise reduction of telephoto
    Improved clarity and color of Nightscape
    Improved brightness and clarity in extreme low light scene of Nightscape
    System
    Optimized Double Tap to Wake
    Fixed issues with Ambient Display
    Improved the audio quality for voice calls from third-party apps
    Improved touch sensitivity for screen
  9. elanglois
    Lollipop Jun 7, 2019
    elanglois , Jun 7, 2019 :
    Yes! It cant overcharge. Its smarter than the user and this lets your phone optimize! Trust me
    G1558842425747 and MR.BEN312 like this.
  10. MR.BEN312
    Honeycomb Jun 7, 2019
    MR.BEN312 , Jun 7, 2019 :
    yes that is so true...
  11. Tammi Simms
    Cupcake Jun 7, 2019
    Tammi Simms , Jun 7, 2019 :
    Hello everyone, I am new to the oneplus world. Brought my 7 pro in mainland China about 2weeks ago. I thought it will work normal like all the other phones. But nope, I can't login to my google account. Had a look online, I think it's down to the OS. So, can anyone pls tell me how can I change that? TIA
  12. elanglois
    Your phone optimizes itself. Leave it plugged in overnight for best results
  13. SBANZM
    Donut Jun 7, 2019
    SBANZM , Jun 7, 2019 :
    elanglois
    OnePlus cannot make the notifications dark without breaking applications​
    Breaking apps? Can you elaborate? Thanks
  14. Rahstyles
    Gingerbread Jun 7, 2019
  15. vriesdejoop
    vriesdejoop , Jun 7, 2019 :
    forget AOD, not needed
  16. Rohit Yadav G
    Cupcake Jun 7, 2019
  17. Rohit Yadav G
    Cupcake Jun 7, 2019
  18. elanglois
    mini apps assume that the notification is white. Therefore, it will use custom text colors that are very dark. The oldest doesn't know that the van has been changed to a dark color. The ellesse is only change the default font colors not the custom ones. what you end up with is very dark text on a black background and you won't be able to see your notification.
    substratum uses custom overlays specific to each app that does this. However, every time that that app is updated you have to update the overlay otherwise the Apple crash. It's a constant shell game of overlays and updates.
    just wait for Q. Google has enough clout to force developers to upgrade how they do things. once the global dark mode in queue is supported by newer apps then you won't have to worry about it
    SBANZM likes this.
  19. SBANZM
    Donut Jun 7, 2019
    Thank you! I can see clearly now..
  20. elanglois
    Should have said ʾMany apps' not 'mini' ... Google Voice Typing, but you get the idea. When apps support Q we should get black notifications from them
    SBANZM likes this.
