236
OxygenOS 9.5.4/9.5.5 for OnePlus 7 Pro Global/EU [9.5.6 for the US]
  1. BlackKnight2332
    Gingerbread May 26, 2019
  2. sunil kumar200
    Cupcake May 26, 2019
  3. R1558854020059
    Donut May 26, 2019
    R1558854020059 , May 26, 2019 :
    works for me gives me a haptic feedback everytime I double tap to wake.
    sunil kumar200 likes this.
  4. elanglois
    Lollipop May 26, 2019
    elanglois , May 26, 2019 :
    Been there done that. My 3T is rooted. No need to defend it. I downloaded the update and installed it, the incremental! I do just fine without the updater and its never done anything for me. Its useless
  5. BlackKnight2332
    BlackKnight2332 , May 26, 2019 :
    The camera just needs software improvements in my opinion. The camera can take great photos just not consistent.
    R1558910837372 and Hitman424 like this.
  6. elanglois
    Works fine for me
    R1558854020059 likes this.
  7. sunil kumar200
    sunil kumar200 , May 26, 2019 :
    May be the issue is with my device...it isn't working at all...it worked fine for an hour or two after the update
  8. BlackKnight2332
    mines been hit or miss as well. worked great day 1, day 2 started acting up. I turned it off and back on. Still has moments.
  9. Mukund760
    Honeycomb May 26, 2019
    Mukund760 , May 26, 2019 :
    um... I am not defending anything. I was just trying to help you, since this method fixed the updater for me. :)
  10. R1558854020059
    Donut May 26, 2019
    that's weird. before I replied I did it like 10 times and it works FYI I still have the in built screen protector.
  11. elanglois
    And you downloaded how big of a file when 100MB would have worked?
  12. Mukund760
    well, I don't have any problem with downloading big files.
  13. elanglois
    Misses the point
  14. akks
    Ice Cream Sandwich May 26, 2019
    akks , May 26, 2019 :
    First of all, all these issues and feedbacks are well reported, except I think volume key ( may be only my device has got that )
    Night mode when turned on and if you encounter any lockscreen which require your fingerprint, the display lights normally, and night mode turns back on after a few seconds only. Its the same in system lockscreen or app lockscreen. It's a known bug, already reported by many.
    Video calls I meant any app, Google duo, WhatsApp, Native video call. You don't give a rat's *** doesn't mean the feature is supposed to act retard. Don't expect everyone to use their phone the same dumbo way others use.
    Thank you for your advice to turn off the advance battery optimisation! That's an awesome solution I never had thought of!
  15. Mukund760
  16. Tomy159
    Eclair May 26, 2019
    Tomy159 , May 26, 2019 :
    Hi guys you maybe can help.
    I want install last update from oxygen updater.
    It's say go to recovery mode then choice language and then install from sd
    Problem is I go to recovery want password fine put mine from lock screen then language is three there fine use English and then I got three option wipe data, advance and exit nothing else
    If I go to advance there is restart fastboot restart to recovery and V2
    Nothing else ( restart recovery) is restarting and goes back from beginning
    So there is no option to install update from sd or internal sd.
    Did have someone same problem? Or please how to fix?
  17. akks
    Agree. It isn't consistent. Sometimes awesome photos, sometimes awkward. Hope that it will be fixed in future updates
    sergi71bdn likes this.
  18. elanglois
    OK. These aren't even bugs.
    The fingerprint sensor needs light to work, and you can't change the color or intensity and have it work right. If it turns night mode off to read your fingerprint and then turns it back on for you then it is working perfectly!
    The pop-up camera isn't retarded, just your expectations. The OS can only do what the app asks. The app says "open front camera device", and the OS will naturally raise the camera at this time since the OS won't know when the video call app connects. Its has to raise the camera when the device is opened because there is no other reliable way to know when its needed. And why do you care if it's a few seconds early??
    Advanced battery optimization kills apps and stops them from running. It does what it says on the tin. If you don't like it, turn it off.
    Hitman424, Dhruv Weaver and Hydra Bob like this.
  19. G_Kiri_Bogach_Mqsp
    G_Kiri_Bogach_Mqsp , May 26, 2019 :
    With this new update I'm having problems with custom anchor in developer mode.
    Default 411
    Small 470
    If you set it to something in the middle it goes big instead...
  20. MarkoBatrac
    MarkoBatrac , May 26, 2019 :
    9.5.5 eu
    Tomy159 likes this.
