15
OxygenOS 9.5.4 for OnePlus 7 Pro 5G
  1. Swejuggalo
    KitKat Jul 5, 2019
    Swejuggalo , Jul 5, 2019 :
    On 9.5.5? If that is the the newer version it must have been upgraded from apkmirror at some point.
    #81
  2. chistery
    Honeycomb Jul 5, 2019
    chistery , Jul 5, 2019 :
    I haven't upgraded mine, so hopefully someone else will confirm their version after 9.5.5
    #82
  3. xenom0rph
    Gingerbread Jul 5, 2019
    #83
  4. NYanakiev7
    Eclair Jul 5, 2019
    #84
  5. halo86
    Froyo Jul 5, 2019
    halo86 , Jul 5, 2019 :
    I need your help. I bought the Oneplus 7 Pro 5G on ebay and now I'm using the phone in Switzerland with a Swiss carrier. 5G is already available in Switzerland but I only get a 4G connection. How is that possible? The device has definitely no SIM lock as 4G is available... Any idea what to do? Thanks for your help!
    #85
  6. wmAkuma
    Cupcake Jul 5, 2019
    wmAkuma , Jul 5, 2019 :
    5g on eBay? go to settings network and see if shows the 5g on this setting
    #86
  7. wmAkuma
    Cupcake Jul 5, 2019
    #87
  8. halo86
    Froyo Jul 5, 2019
    wmAkuma
    and the model should be gm1920​
    My prove... As you can see 5G is enabled. However I don't get a connection even when standing right next to a 5G antenna.
    #88
  9. wmAkuma
    Cupcake Jul 5, 2019
    your carrier supports 5G? here in UK only EE supports for now, so if I put other SIM in it, I won't have access to 5g
    #89
  10. halo86
    Froyo Jul 5, 2019
    Yes, my carrier (sunrise) supports 5G since beginning of may... In the UK vodafone also started their service, right? Would be interesting to see if a vodafone SIM would get a 5G connection with the Oneplus 7 Pro 5G
    #90
  11. Swejuggalo
    KitKat Jul 5, 2019
    My guess is that you need to call your carrier. I'm not into the details on 5G networks but there should be info available somewhere. I can't really find any 100% reliable info on this but what I found is that it supports "NSA / Sub6 / mmWave" types of networks. Since 5G is relatively new your carrier might need to do some stuff on their side to get it working.
    #91
  12. halo86
    Froyo Jul 5, 2019
    Thanks for your reply. I already called the technical suppprt of my carrier twice but the guys there have no clue... I guess I need to be lucky to somehow get to talk to a 5G network expert when I call the support...
    #92
  13. xenom0rph
    xenom0rph , Jul 5, 2019 :
    you cant just put sim in 5g phone and expect 5g
    the network you use needs to switch you to a 5g service.
    #93
  14. E1559235615124
    Donut Jul 6, 2019
    E1559235615124 , Jul 6, 2019 :
    You will need a 5G plan from your mobile network for it to work if you have a 4G sim 5G won't work
    #94
  15. halo86
    Froyo Jul 6, 2019
    halo86 , Jul 6, 2019 :
    With my carrier you just need to activate the 5G option and pay around £7 per month more and you're ready to use the 5G network... Still think my carrier just doesn't support the Oneplus :-(
    #95
  16. Killian COMPAGNON
    Froyo Jul 6, 2019
    #96
  17. chistery
    Honeycomb Jul 7, 2019
    chistery , Jul 7, 2019 :
    Vodafone 5G has gone live, so it's two networks in the UK now.
    #97
  18. U1533748368606
    Cupcake Jul 7, 2019
    #98
  19. halo86
    Froyo Jul 8, 2019
    halo86 , Jul 8, 2019 :
    Can someone that is using the Oneplus 7 Pro 5G with EE in the UK do me a favor. Can you please dial *#*#4636#*#* --> select phone information (first option) --> check what preferred network is selected
    Standard for me is TD-SCDMA/CDMA/UMTS. No possibility to select 5G. How is it for you? Thanks a lot for your help!
    #99
  20. xenom0rph
    Gingerbread Jul 9, 2019
    halo86 likes this.
