122
OxygenOS 9.5.5 for OnePlus 7
  1. Uncle timmy
    Gingerbread Jun 18, 2019
    Uncle timmy , Jun 18, 2019 :
    There is Google lens in camera. Go into camera and press and hold on the screen.
    You are correct, no pocket mode
    For battery, charge over night a few times to let android do its optimization. Also, go into settings, apps and go through the apps and turn off background data for the apps you don't want to have background data for. You'll end up with very decent battery life. I get 8 to 10 hours sot.
  2. H1560497954467
    Cupcake Jun 18, 2019
    H1560497954467 , Jun 18, 2019 :
    thanks my friend.
    how to make fingerprint scanner work smooth and fast?
  3. Rajat_kumar_95
    Rajat_kumar_95 , Jun 18, 2019 :
    please give more attention to the camera department. It definitely needs improvement. And please give equal importance to oneplus 7 as u guys give to oneplus 7 pro. please please. Don't discriminate.........
    Amruta234 likes this.
  4. Pavithran987
    Rajat_kumar_95 likes this.
  5. Ravi_Shahane
    Amruta234 and Dinesh_LDK like this.
  6. John j
    Jelly Bean Jun 18, 2019
    Ravi_Shahane likes this.
  7. Sanket varal007
    Eclair Jun 18, 2019
    N1560391088911 likes this.
  8. E1560328765988
    Amruta234 and N1560391088911 like this.
  9. althafrahsan
    Froyo Jun 18, 2019
    althafrahsan , Jun 18, 2019 :
    *OIS not working properly , while testing video recording in 4k mode ,OIS is fine , but recording in 1080p and 1080p60fps it's not working , Some times it's working on 1080 , if you try 5 times you will get worse result in 4 times . tried with different lighting conditions , every time 4k giving better stebilised videos , 1080 failed in OIS
    * Touch issues , many times I feels like my touches not registered , while playing pubg I need to touch 3-4 times to open the setting icon on pubg
    * Finger print scanner , gone worse after 9.5.5 , finger print scanner can be rated 1 star out of 5 . face unlock is fast and reliable , even face unlock working in night times also .
    Atanu Maji and N1560391088911 like this.
  10. N1560391088911
  11. I1560023915160
    Donut Jun 18, 2019
  12. csrcsr07
    Marshmallow Jun 18, 2019
  13. KathiravanJLR
    Froyo Jun 18, 2019
    KathiravanJLR , Jun 18, 2019 :
    when will be the next update for oneplus7..after 9.5.5 the adaptive birghtness is not good in 9.5.5 update
  14. KathiravanJLR
    Froyo Jun 18, 2019
  15. hemant529
  16. G_Bipin_Parmar_NGrn
    G_Bipin_Parmar_NGrn , Jun 18, 2019 :
    thank you for considering this issue..
    even after said update one plus 7 is not producing good images.. seema saturation is high and colour capututred looks artificial many way.. needs more and perfect improvement...
    hope one plus will look at this issue too.
  17. shubhamsinghshubham777
    shubhamsinghshubham777 , Jun 18, 2019 :
    Can't see the option to disable noise cancellation on my OP7. Am I the only one who is not able to find it yet? Or is it not really there?
    I wanna disable it because there's too much noise cancellation while I'm calling someone and they're not able to hear my voice clearly because of this.
  18. Y1560686581026
  19. shubhamsinghshubham777
    For casual (non-gamer) users.. about - 6-7 hours of SOT
    and
    For heavy gamers.. about 4 hours tops
    (that's only my experience with my device.. can't say about anyone else.. the values may vary for others).
  20. Y1560842210955
    Y1560842210955 , Jun 18, 2019 :
    The main reason of buying this phone is for camera. I observed the main rear camera is by default beauty mode is enabled and there is no option to disable it. Every time beauty mode enable nobody will like. there should be option to turn off the beauty mode in the back camera.
    please help this should be fixed [e]1f64f[/e] thanks for the help in advance.
