265
OxygenOS 9.5.7 for OnePlus 7 Pro
  1. Swejuggalo Jelly Bean Jun 17, 2019
    Swejuggalo, Jun 17, 2019 :
    As far as I know the update is basically the same as all the other 4G versions. Minor T mobile adaption added only
    C1558414574201 likes this.
  2. hardikrdesai Gingerbread Jun 17, 2019
  3. I1560366583561 Cupcake Jun 17, 2019
    I1560366583561, Jun 17, 2019 :
    Why is the main sensor used while zooming in?! Then what's the point of saying optical zooming?!
    Right now the zoom lens is used only for Portrait Mode!!
  4. Swejuggalo Jelly Bean Jun 17, 2019
    Zoom in slowly in some half dark environment. You notice a pretty different light change at 3x zoom. That is were the zoom lens jumps in. Similar when zooming out. Telephoto lens switch can be seen as some change in the light on the screen.
    Loper_fan likes this.
  5. Pranjal.Goel.16 Honeycomb Jun 17, 2019
  6. I1560366583561 Cupcake Jun 18, 2019
    I1560366583561, Jun 18, 2019 :
    I don't think the camera is switching to telephoto even at 3x . just cover the telephoto lens with your finger and try to zoom in!!
    You'll still be able to get 3x zoom.
    But if you cover the primary sensor, you just can't zoom in!!
    I don't think the telephoto is used other than for portrait shots!!
  7. falconmoonpunch Froyo Jun 18, 2019
    falconmoonpunch, Jun 18, 2019 :
    Good update battery drain just needs to be addressed really because mine is draining faster than I logically think it should
  8. Slayerz Gingerbread Jun 18, 2019
    Slayerz, Jun 18, 2019 :
    I took this picture a few hours ago with the Main Camera lens and it looks very impressive and I can see every little detail right on the spot even on indoor settings but.... for some odd reasons if I take the same picture with a person standing over there instead of the car then I don't get the same level of details like for example the person's face because it looks so soft and little bit blurry.
    It only happens with people, maybe the lens do not capture the skin colors the correct way because I've tested this so many times and I get the same results only when I take pictures from people or any person!
    Hitman424 likes this.
  9. Hitman424 Gingerbread Jun 18, 2019
  10. G_Marcin_Benko_YpgN Eclair Jun 18, 2019
  11. akks Ice Cream Sandwich Jun 18, 2019
  12. G_Marcin_Benko_YpgN Eclair Jun 18, 2019
    G_Marcin_Benko_YpgN, Jun 18, 2019 :
    I can't tell... just have no time to test it.
    but it is working fine with my 9.5.4
  13. U1544644647589 Froyo Jun 18, 2019
  14. Swejuggalo Jelly Bean Jun 18, 2019
    Swejuggalo, Jun 18, 2019 :
    Seems to jump to telephoto lens for me at 3x. Same behavior on 2 versions of the cam now
  15. I1560366583561 Cupcake Jun 18, 2019
    Did you try covering the telephoto lens at 3x or Above?!
  16. Swejuggalo Jelly Bean Jun 18, 2019
    Think I see what is happening... If camera is shut down and starts up fresh, then zoom is allowed higher than 3x without switching. Go much high and it triggers the zoom. Go back and forward go see it switching at 3x all the time (but no at a fresh start... Odd)
  17. D1560498307984 Cupcake Jun 18, 2019
  18. D1560498307984 Cupcake Jun 18, 2019
  19. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    KeepTransisting, Jun 18, 2019 :
    You posted this same nonsense in the AMA thread. Why are you spamming this around?
  20. D1560498307984 Cupcake Jun 18, 2019
    D1560498307984, Jun 18, 2019 :
    to whom this reply
