265
OxygenOS 9.5.7 for OnePlus 7 Pro
  1. Swejuggalo
    KitKat Jun 28, 2019
    Swejuggalo , Jun 28, 2019 :
    If the phone built-in updater skipped 9.5.7 it will automatically include everything from previous updates.
    The only time you need to think about the updates is if you use Oxygen Updater. Then you need to know when to download the full update or the incremental update (I think it suggest full update if a update is missing though, but it can be good to double check just in case)
    DazOnDayzUk likes this.
  2. vriesdejoop
    Ice Cream Sandwich Jun 28, 2019
  3. vriesdejoop
    vriesdejoop , Jun 28, 2019 :
    sorry, but to be blunt, absolutely not true... ..
    oxygen update used exactly the same OTA's as when you wait for the OP ota.
    you only have to know what you are doing if you unlocked and rooted you're phone, then only use full ROM, and be sure you understand the a/b partitioning of your system
  4. Swejuggalo
    KitKat Jun 28, 2019
    vriesdejoop
    you only have to know what you are doing if you unlocked and rooted you're phone, then only use full ROM, and be sure you understand the a/b partitioning of your system​
    You could manually select full update or incremental in Oxygen Updater, even choose to download to files to other phones than your own model, depending on what functions you have unlocked inside of the app... So my point still stands. If you are not on the latest version prior a new update don't try a incremental update...
    Or do you mean that Oxygen Updater has several incremental updates that updates from more than the latest version?
    I was referring to being on 9.5.5 for example and update to 9.5.8.
  5. R1558910837372
    Froyo Jun 28, 2019
    R1558910837372 , Jun 28, 2019 :
    yes it will
  6. Louis008
    Cupcake Jul 16, 2019
    Louis008 , Jul 16, 2019 :
    I have tried doing the local upgrade for 9.5.7 as I'm on 9.5.5 but It doesn't seem to be working. any ideas/help?
    T
    Thanks
  7. Swejuggalo
    KitKat Jul 16, 2019
  8. Louis008
    is there any news on when it will be available?
  9. Swejuggalo
    KitKat Jul 16, 2019
  10. Swejuggalo
    KitKat Jul 16, 2019
    Swejuggalo , Jul 16, 2019 :
    Last update was the 4th July. Everything between 3 weeks, and beyond 1 month between updates should be expected currently. Everything faster than 1 time per month is what I call a bonus [e]1f609[/e]
  11. Louis008
    Typical the highest model doesn't get the newest update thanks for your help much appreciated.
  12. Swejuggalo
    KitKat Jul 16, 2019
    Well. Don't look too much on the numbers. 5G got the big camera update at 9.5.5. Regular Pro at 9.5.7. So the numbers does not mean higher is better. The only thing the number really tell is kind of an approximation of the amount of updates it has received.
  13. M1563367493996
    Cupcake Jul 18, 2019
  14. Aramalp
    Eclair Jul 18, 2019
    Aramalp , Jul 18, 2019 :
    nee update 9.5.10
  15. Justinnov23
    Gingerbread Jul 26, 2019
    Justinnov23 , Jul 26, 2019 :
    anyone facing this issue??any solutions for this annoying notification??Any help is Welcome...
  16. KrimoParisien
    Donut Aug 15, 2019
  17. Swejuggalo
    KitKat Aug 15, 2019
    Swejuggalo , Aug 15, 2019 :
    You got an notification icon before right? Looking like a cog. If you see that after a restart press the notification until you see this. Then press the i symbol and force stop it. Hopefully it does not return.
    Justinnov23 likes this.
  18. Justinnov23
    Gingerbread Aug 15, 2019
    Justinnov23 , Aug 15, 2019 :
    thanks bro..will try and tell u
