265
OxygenOS 9.5.7 for OnePlus 7 Pro
  1. antonyjen Honeycomb Jun 7, 2019
  2. allroadusa Eclair Jun 7, 2019
    allroadusa, Jun 7, 2019 :
    Hi,
    I confirm. Great work done ! Pictures with any lens are much more consistent and sharp.
    SwissMario likes this.
  3. Spelt Ice Cream Sandwich Jun 7, 2019
    Spelt, Jun 7, 2019 :
    Got it in the US with Oxygen Updater. Downloaded and installed. So far no problems.
  4. Niklasg85 Gingerbread Jun 7, 2019
  5. B1559604056812 Cupcake Jun 7, 2019
    V3X11 likes this.
  6. Spelt Ice Cream Sandwich Jun 7, 2019
    Would not use a US version if you are in India. No telling what it would do.
    nateavi and Pranav.k like this.
  7. allroadusa Eclair Jun 7, 2019
    Issue is all about OnePlus launcher's ability to use the work profile Try using MS launcher before enrollment: it manages work profile perfectly and solved the issue I faced with AirWatch/Workspace one.
  8. G_ayush_madan_YhBr Honeycomb Jun 7, 2019
  9. tukur36 Gingerbread Jun 7, 2019
    tukur36, Jun 7, 2019 :
    Yes, for triple cameras if there's one. Lol
  10. Spelt Ice Cream Sandwich Jun 7, 2019
  11. captsakis Gingerbread Jun 7, 2019
  12. bhavinder001 Gingerbread Jun 7, 2019
    bhavinder001, Jun 7, 2019 :
    do s
    do share your feedback!!!
  13. Spelt Ice Cream Sandwich Jun 7, 2019
    I like the post OTA picture much more. The yellow tinge in the pre OTA picture doesn't look good to me.
    nateavi likes this.
  14. bhavinder001 Gingerbread Jun 7, 2019
    This is the best thing about OP. Feedback/criticism is taken positively and they work on it everyday to make the user experience better. I love you 3000 OP.
    Thanks
    nateavi likes this.
  15. mpretty Cupcake Jun 7, 2019
    mpretty, Jun 7, 2019 :
    Along with everyone else, I want to download and install the new 9.5.7 update. However, I'm not sure if that is possible with the T-Mobile variant. Looking for some clarification. Here is what I've done:
    Per recommendations that I read here, I installed the Oxygen Updater app. From there, I enabled Advanced Mode in the settings, and that gave me the option to download the 9.5.7 update zip file.
    I successfully downloaded the file, and the installation instructions appeared. I read through the instructions, but when I go to install a local update, I don't see that option anywhere. When I go to System > Update, the only option is to "check for update"... checking for an update returns nothing.
    Am I just missing something? Or is this locked down by T-Mobile, and I just can't do this manually?
  16. react117 Donut Jun 7, 2019
    react117, Jun 7, 2019 :
    I still believe the GCam works better than the stock camera. The stock camera still tends to brighten things up. Here's a sample. The one with no watermark is the output of GCam. Both are shot on auto.
  17. nateavi Gingerbread Jun 7, 2019
    nateavi, Jun 7, 2019 :
    Download VPNhub. It's an app you'd find in the play store. The free version normally has a proxy based off the US. At times, you'd get Netherlands.
  18. nateavi Gingerbread Jun 7, 2019
    Could it be that night mode is causing that? Ensure it's switched off. It causes a yellowish tint in the display (that's how night mode works btw). You can find the toggle in the notification shade.
  19. vj4mqntm Froyo Jun 7, 2019
    vj4mqntm, Jun 7, 2019 :
    Only oneplus is the one who have a good PPI(Practical Procsses Improvement) team who work with end user feedbacks and try to improve that's whay I chose oneplus I like the way they work.
    In world no one is perfect but the abality to improve the things is bes practics
    Keep it up oneplus team.
  20. Q1559887712220 Cupcake Jun 7, 2019
    Q1559887712220, Jun 7, 2019 :
    getting some crash issues. system UI is getting crashed a few times and even some application too.
