265
OxygenOS 9.5.7 for OnePlus 7 Pro
  1. Cervantes
    Lollipop Moderator Jun 8, 2019
    Cervantes , Jun 8, 2019 :
    Hi
    The update thread is a thread of questions and/or commentary
    Please, read the first post
    Thread merged
  2. mbcool
    Honeycomb Jun 8, 2019
    mbcool , Jun 8, 2019 :
    Color reproduction difference in 3x vs normal lense as can be seen below
  3. Rafi87
    Eclair Jun 8, 2019
  4. alanrushmore
    Gingerbread Jun 8, 2019
    alanrushmore , Jun 8, 2019 :
    Connect to VPN Canada, then check for update..
  5. John_Wan
    Cupcake Jun 8, 2019
    John_Wan , Jun 8, 2019 :
    Can anybody share this update file? My Op7 pro runs the hydrogenOS(default version in China), and there is some trouble with getting the newest OxygenOS update.
    Thanks a lot.
  6. H1560000678575
    Donut Jun 8, 2019
    H1560000678575 , Jun 8, 2019 :
    Lol, why you don't have small OTA updates? Why you download a big update (2GB)?
  7. aj.au
    Eclair Jun 8, 2019
    aj.au , Jun 8, 2019 :
    I don't know, I went into the system update app and cleared cache then retried again , got a 180mb update and it failed to install too. then i clicked try again and it took me back to the 2gb update again.... I have no idea why it's not working
    Maspos likes this.
  8. Guitarzan
    Donut Jun 8, 2019
    Guitarzan , Jun 8, 2019 :
    Did this latest update improve the standard 48mp camera? I thought the pictures looked washed out or kind of faded in good light. Just didn't seem to handle bright light too well.
    I returned mine for another issue but would love to re purchase if tbe standard camera has improved to be more in line with other flagships .
  9. Rohitkumar2830
    Froyo Jun 8, 2019
  10. JNewms
    Donut Jun 8, 2019
    JNewms , Jun 8, 2019 :
    Is there a download for those of us that want to update manually? I don't like waiting for staged rollouts and can just flash stock via fastboot if something goes wrong
    Edit: Disregard, found the update zip. Time to flash!
  11. H1560000678575
    Donut Jun 8, 2019
    Do you have unlocked bootloader? This can be a problem but I am not sure (I don't have OP) but I am thinking about buying OP7Pro :)
  12. aj.au
    Eclair Jun 8, 2019
    no bootloader is untouched I haven't touched or modified anything on the phone . it's definitely a great device though came from a op6t and it's a big upgrade in the important places
    H1560000678575 likes this.
  13. JNewms
    Donut Jun 8, 2019
    Having just an unlocked bootloader wouldn't affect any updates. There would have to be a custom kernel, recovery, or some other modification to cause install issues.
  14. santoshsavanur
    The Lab - OnePlus 7 Pro Reviewer Jun 8, 2019
    santoshsavanur , Jun 8, 2019 :
    Post in thread '[The Lab] OnePlus 7 Pro Review - By Santosh Savanur' by santoshsavanur has been reported by santoshsavanur. Reason given:
    Content being reported:
  15. Y1558202132385
    Cupcake Jun 8, 2019
  16. H1560000678575
    Donut Jun 8, 2019
    Maybe try Oxygen Updater from Play Store (or OnePlus Updater - I don't remember).
  17. karthike998
    Cupcake Jun 8, 2019
  18. Lunatico
    Jelly Bean Jun 8, 2019
    Lunatico , Jun 8, 2019 :
    Do you know what incremental means?
    Ncruze likes this.
  19. karthike998
    Cupcake Jun 8, 2019
  20. Lunatico
    By reading the very first post dammit!
    Ncruze and G_Brandon_Clark_kPTj like this.
