265
OxygenOS 9.5.7 for OnePlus 7 Pro
  1. Huigiebaby
    Honeycomb Jun 11, 2019
    Huigiebaby , Jun 11, 2019 :
    Nope, you are the only one.
  2. F1559231195657
    Cupcake Jun 11, 2019
    F1559231195657 , Jun 11, 2019 :
    When will this be rolled out to EE customers in the UK with the OnePlus 7 Pro 5G please? If it's going to be ages I'll work out how to use a VPN. Thanks.
    JSBUK likes this.
  3. Joey463
    Joey463 , Jun 11, 2019 :
    My battery improved slightly. I'm averaging around 15 minutes more than before. But battery life fully depends on your usage.
  4. Joey463
    I would say to just be patient. It will come eventually. I only received mine on Saturday. Which was quicker than receiving the previous update.
    Patience is key
    JSBUK likes this.
  5. anilkigal
  6. OPOBEAST
    dhawal.d7 and rsklogin like this.
  7. MattBoxer
    Gingerbread Jun 11, 2019
    MattBoxer , Jun 11, 2019 :
    For me, since 9.5.7 (EU device) warp charge is borked for me, it changes between warp, normal and no charging about every 5 seconds, my old 5 cable does the same but funnily enough warp charge pops up with it, and my 5 dash charger works fine (kind of limited to 1amp though). And once the phone is about 90% the issue goes away completely. Also a factory reset didn't fix it and I know for sure I didn't have it on 9.5.5 because my phone vibrates every time it switches back to warp charge (which happens a lot and repeatedly as well as the animation on the lock screen) and its never done that before. (here is a screen rec of the factory mode in the fast charge setting with the warp charge: https://drive.google.com/open?id=1-2jgFTouvm170uMDDuB2roksm7gUL6IA)
  8. OPOBEAST
    OPOBEAST , Jun 11, 2019 :
    MattBoxer
    For me, since 9.5.7 (EU device) warp charge is borked for me, it changes between warp, normal and no charging about every 5 seconds, my old 5 cable does the same but funnily enough warp charge pops up with it, and my 5 dash charger works fine (kind of limited to 1amp though). And once the phone is about 90% the issue goes away completely. Also a factory reset didn't fix it and I know for sure I didn't have it on 9.5.5 because my phone vibrates every time it switches back to warp charge (which happens a lot and repeatedly as well as the animation on the lock screen) and its never done that before. (here is a screen rec of the factory mode in the fast charge setting with the warp charge: https://drive.google.com/open?id=1-2jgFTouvm170uMDDuB2roksm7gUL6IA)​
    You should contact OnePlus about that. I also have an EU model on 9.5.7 but never experienced such issue.
    MattBoxer likes this.
  9. Spelt
    Ice Cream Sandwich Jun 11, 2019
    Spelt , Jun 11, 2019 :
    You are the only one!
  10. rikkysingh
    rikkysingh , Jun 11, 2019 :
    any idea why my OnePlus 7 used more than 75gb in data this morning, says it was Android OS?
  11. MattBoxer
    I did, they just said to reinstall 9.5.7, did that and its still the same. I'll get back to them again but its such a strange issue, I would like to downgrade to check but I can't without a custom recovery. :(
    OPOBEAST likes this.
  12. Spelt
    It just wanted to see if you'd panic? (That is kind of high, maybe you have a data leakage somewhere?)
    rikkysingh likes this.
  13. F_Hisham_Wasfy_Hassan_Aj
    Eclair Jun 11, 2019
    F_Hisham_Wasfy_Hassan_Aj , Jun 11, 2019 :
    Day 2 of using 9.5.7 and the list increases...
    1. Popup camera still pops up whenever a video call is received.
    2. Camera has improved alot but still focus is not accurate always.
    3. Wide angle and telephoto are still noisy and blurry in low light.
    4. Images from wide angle and telephoto are very less detailed and poor quality.
    5. Can't scroll notification panel while on a call.
    6. Battery backup still not the best. 5-6 hours sot hardly.
    7. RAM management worst always 5+ gb in use out of 8.
    8. Heating while charging and slight heating while normal usage.
    9. Fingerprint scanner often fails to recognize.
    10. Sim cards continuously fluctuating on internet. Keep connecting disconnecting
    11. The edges of the screen often become unresponsive.
    12. Selfie camera reflects blue colored circles when there are lights in the background.
    13. The rear camera often distorts lights (Lamps, street lights, etc )
  14. Z1560225430937
    Z1560225430937 , Jun 11, 2019 :
    can we expect a similar update for the standard OnePlus 7?
    also, can I use the 9.5.7 update on non pro OP7 or will that cause any issues?
  15. Gav_W86
    Starting Point Expert Jun 11, 2019
    Gav_W86 , Jun 11, 2019 :
    To be fair, they didn't say "1. Popup camera still pops up whenever a video call is received. " was going to be 'fixed' in 9.5.7. Believe that will be in a future build (in theory it is the phone responding correctly to the call of the camera by the app, it is just more of an issue now the camera pops up)..
  16. I1558436067746
    Eclair Jun 11, 2019
  17. FRJerome
    FRJerome , Jun 11, 2019 :
    And you know how to take good photos... ?
    Well ...
  18. 3XM76
    Froyo Jun 11, 2019
    3XM76 , Jun 11, 2019 :
    And there we go :D :D In case you didn't get the point - it was a simple comparison between two phones on automatic settings in same lighting conditions - just to get some reference on how they handle the exposure, focus, noise etc. Not exactly photography master class. Nothing special, difficult, artistic or scientific about it. But hey - whatever rocks your boat ;)
  19. LamarFrazier
    Froyo Jun 11, 2019
  20. Rexisrex
    Rexisrex , Jun 11, 2019 :
    Alert iPhone user amongst us...
    have reported to moderator. spamsters...
