265
OxygenOS 9.5.7 for OnePlus 7 Pro
  1. M_Khuvung Eclair Jun 12, 2019
    M_Khuvung, Jun 12, 2019 :
    Google Map keeps crashing constantly on my OP 7 Pro.
    Is it the phone or the problem is from Google.
    Please advise?
    thanks
  2. Rexisrex Gingerbread Jun 12, 2019
    Rexisrex, Jun 12, 2019 :
    try clearing data and cache of Google maps and check
    M_Khuvung likes this.
  3. M_Khuvung Eclair Jun 12, 2019
    that helped.
    thanks
  4. D1559157572656 Cupcake Jun 12, 2019
    D1559157572656, Jun 12, 2019 :
    when this new update is going to be available worldwide? i live in europe and haven't recieved anything yet
  5. Rexisrex Gingerbread Jun 12, 2019
    you can try VPN set to Germany and try. else download Oxygen Updater app from playstore and flash the OTA from there. it's safe
  6. D1559157572656 Cupcake Jun 12, 2019
    but the phone will not be rooted or something right?
  7. Rexisrex Gingerbread Jun 12, 2019
    no root. full stock.
  8. D1559157572656 Cupcake Jun 12, 2019
  9. rajamcs Cupcake Jun 12, 2019
    rajamcs, Jun 12, 2019 :
    after update, I noticed my screen goes dull automatically with ambient display. without changing position of mobile,if I turn off and on ambient display, display becomes bright. I am noticing only after this update. please advise
  10. Rexisrex Gingerbread Jun 12, 2019
    are you talking about Adaptive Brightness?
  11. rajamcs Cupcake Jun 12, 2019
    yes, is it not same ambient display and adaptive brightness?
  12. Rexisrex Gingerbread Jun 12, 2019
    rajamcs
    yes, is it not same ambient display and adaptive brightness?​
    no ambient display is like always on display in Sammy device. you can get notifications alerts etc without turning on lockscreen.
    For a very long time now in all android versions I stopped using adaptive brightness. it actually has an impact on battery life IMPO. also only scenario it works is on bright outdoor condition. but i just push my manual brightness from say 60% to 95% outside.
    rajamcs likes this.
  13. Vlad_Iustinian Cupcake Jun 12, 2019
    Vlad_Iustinian, Jun 12, 2019 :
    Hello,
    So I am from Romania (Eastern Europe) and I still haven't got the 9.5.7 update. When I go and try update my phone, it says that it is up to date. Is it only my phone or will it eventually update? It already has been a week since the release of the update and I really want to see those improvements. Thank you very much for your hard work !
    Kind regards, Vlad
  14. JSBUK Cupcake Jun 12, 2019
    JSBUK, Jun 12, 2019 :
    Did you get an answer? Did you manage to do it through A VPN? I've tried a few times but can't get it to work....
  15. M1560335188599 Cupcake Jun 12, 2019
    M1560335188599, Jun 12, 2019 :
    Just got the phone, and I think it is awesome. When will this update hit Europe, more specifically Denmark? Would like to be able to use the phones built-in software updater, not a big fan of messing with zip's and VPN's.
  16. D1559157572656 Cupcake Jun 12, 2019
    hi, should i use the full update or incremential ? as the reccomended is incremential?
  17. Slayerz Gingerbread Jun 12, 2019
    Slayerz, Jun 12, 2019 :
    Oh yes! I can't believe either, last Sunday I was on a family trip and it was so pretty outside and very sunny and almost 98% of my pictures came out soft, man I was so heartbroken because I really wanted to capture all the magic and hapiness of my family but their faces look so soft that I can't believe it, and I if zoom in the pictures it's even worse.
  18. Rexisrex Gingerbread Jun 12, 2019
    full update with a cache wipe is the best option impo
  19. D1559157572656 Cupcake Jun 12, 2019
    shoot i left it as incremential update and its downloading what shal i do, or what will happen if i leave it like that?
  20. Rexisrex Gingerbread Jun 12, 2019
    are you using Oxygen Updater?
