264
OxygenOS 9.5.7 for OnePlus 7 Pro
  1. D1559157572656 Cupcake Jun 12, 2019 at 12:51 PM
  2. Rexisrex Gingerbread Jun 12, 2019 at 12:58 PM
    Rexisrex, Jun 12, 2019 at 12:58 PM :
    Go to Oxygen Updater settings and choose advanced mode . now you'll have full zip in update section. download that.
    now after downloading you need to go phone settings/ software update/ settings wheel in right-hand top corner and choose local upgrade. when you click that you'll see both the files ( incremental and full) choose full. once flash completes go to stock recovery ( vol up + power button keep pressing till you see boot logo). once in recovery go and select wipe data+cache. reboot. you're done.
  3. D1559157572656 Cupcake Jun 12, 2019 at 12:58 PM
    D1559157572656, Jun 12, 2019 at 12:58 PM :
    thanks alot my friend
  4. Vlad_Iustinian Cupcake Jun 12, 2019 at 12:59 PM
    Vlad_Iustinian, Jun 12, 2019 at 12:59 PM :
    So I downloaded the Oxygen Updater and I managed to download the 9.5.7 update.
    JSBUK likes this.
  5. Rexisrex Gingerbread Jun 12, 2019 at 1:00 PM
    Rexisrex, Jun 12, 2019 at 1:00 PM :
    you were the one with 5g phone right? is 5g working with the global ROM update? bcos 5g has a different ROM version
  6. JSBUK Cupcake Jun 12, 2019 at 1:06 PM
    JSBUK, Jun 12, 2019 at 1:06 PM :
    Wow! I wonder why I can't!! Did you use a VPN?
  7. G_Marcin_Benko_YpgN Eclair Jun 12, 2019 at 1:14 PM
  8. Rexisrex Gingerbread Jun 12, 2019 at 1:18 PM
    Rexisrex, Jun 12, 2019 at 1:18 PM :
    nope not yet. and general consensus is not to update global rom on those devices as we aren't sure if the 5g will work post it. hence even Oxygen Updater isn't supporting 5g currently. So waiting looks like a safe option unless someone flashes and finds he hasn't bricked the device. technically you can't hard brick the device as you can recover the device to stock via Qualcomm Q Loader. still why mess up right?
  9. G_Marcin_Benko_YpgN Eclair Jun 12, 2019 at 1:22 PM
    G_Marcin_Benko_YpgN, Jun 12, 2019 at 1:22 PM :
    thanks Mate. I think 5g is supported right now, but I will wait anyway.
    Regards
    pmpbmjafcb and Hitman424 like this.
  10. dhawal.d7 Gingerbread Jun 12, 2019 at 1:27 PM
    dhawal.d7, Jun 12, 2019 at 1:27 PM :
    Yeah... The ambient display too doesn't work in dark.
  11. I1558436067746 Eclair Jun 12, 2019 at 1:40 PM
    I1558436067746, Jun 12, 2019 at 1:40 PM :
    That post was written June 6th, today is June 12th. " A broader rollout in a few days". Do you feel a difference ? 1 week passed
  12. john.fernandezIT Eclair Jun 12, 2019 at 1:51 PM
    john.fernandezIT, Jun 12, 2019 at 1:51 PM :
    There has to be an issue on how OP rolls out updates. Various users with the same update seem to have different issues afterwards. I always download the full update and do a local load. I also use OxygenUpdater to get my updates. I don't seem to have issues with items listed as updated or improved. Could that be the difference.
  13. Rexisrex Gingerbread Jun 12, 2019 at 1:54 PM
    Rexisrex, Jun 12, 2019 at 1:54 PM :
    oh if it's supported just check what's the latest update the app is showing. if it's 9.5.7 you can surely update. the app has been there since long and you can trust it. again like the T-Mobile unit, 5g is also under carrier control. hence the delay. your best case will be if 5g works even after flashing to global ROM. someone has to confirm it. then you'll have quick updates. tied to carrier is the slowest always
    Hitman424 likes this.
  14. Hitman424 Gingerbread Jun 12, 2019 at 1:59 PM
  15. G_Marcin_Benko_YpgN Eclair Jun 12, 2019 at 2:01 PM
    G_Marcin_Benko_YpgN, Jun 12, 2019 at 2:01 PM :
  16. Hitman424 Gingerbread Jun 12, 2019 at 2:01 PM
    Hitman424, Jun 12, 2019 at 2:01 PM :
    no vpn just download oxygen os updater follow the instructions... exactly...
    if you have t mobile phone though it wont work. carrier version you have to wait on t mobile they take a little longer for updates.
    JSBUK likes this.
  17. Rexisrex Gingerbread Jun 12, 2019 at 2:06 PM
  18. Abu -Khulzat Eclair Jun 12, 2019 at 2:06 PM
    Abu -Khulzat, Jun 12, 2019 at 2:06 PM :
    I have red that already and say that on 9.5.7 I still have that issue
  19. JSBUK Cupcake Jun 12, 2019 at 2:06 PM
    JSBUK, Jun 12, 2019 at 2:06 PM :
    Thanks. I'm on EE so I guess I'll have to wait....
  20. Abu -Khulzat Eclair Jun 12, 2019 at 2:07 PM
    Abu -Khulzat, Jun 12, 2019 at 2:07 PM :
    john.fernandezIT
    There has to be an issue on how OP rolls out updates. Various users with the same update seem to have different issues afterwards. I always download the full update and do a local load. I also use OxygenUpdater to get my updates. I don't seem to have issues with items listed as updated or improved. Could that be the difference.​
    I also use full rom to update and still there is an issue with double tap to wake
