265
OxygenOS 9.5.7 for OnePlus 7 Pro
  1. Rexisrex Gingerbread Jun 12, 2019
    Rexisrex, Jun 12, 2019 :
    can you just check one thing. go to settings of oxygen Updater app and turn on advanced mode. now see if it's showing up anything else. but some updates in the advanced mode might need unlocked bootloader with root.
    So a word of caution. if you're ok to unlock etc you can have a go.
  2. Hitman424 Gingerbread Jun 12, 2019
    Hitman424, Jun 12, 2019 :
    oh yes EE is carrier they take a little longer. have a good day brother
  3. unicornZ Gingerbread Jun 12, 2019
  4. richardb20 Eclair Jun 12, 2019
    richardb20, Jun 12, 2019 :
    Versions BA vs AA ??
    My phone says it has 9.5.7.GM22BA (It seems have to have installed this all by itself OTA, I never noticed it happening).
    This thread (AFAIK) talks about the AA version. Is this another Europe vs Rest of World versioning scheme, or has there been a tweaked release?
    R.
  5. Loper_fan Eclair Jun 12, 2019
    Loper_fan, Jun 12, 2019 :
    Packages with build tag GM21AA are intended for the following variants:
    • GM1911: India
    • GM1917: Global/US Unlocked
    Packages with build tag GM21BA are intended for the following variant:
    • GM1913: EU
    Packages with build tag GM27BA are intended for the following variant:
    • GM1920: EU 5G
    Packages with build tag GM31CB are intended for the following variant:
    • GM1915: T-Mobile
    richardb20 likes this.
  6. Rexisrex Gingerbread Jun 12, 2019
    The Variants and the codes
    GM21AA: GM1911: India & GM1917: Global/US Unlocked
    GM21BA: GM1913: EU
    GM27BA: GM1920: EU 5G
    GM31CB: GM1915: T-Mobile (Carrier Locked)
  7. D1559157572656 Cupcake Jun 12, 2019
  8. Predict23 Ice Cream Sandwich Jun 12, 2019
  9. K1558829494153 Cupcake Jun 12, 2019
  10. bibhab1976 Gingerbread Jun 12, 2019
    bibhab1976, Jun 12, 2019 :
    Believe me, I am also on 9.5.7 from india. I am not facing any of the above what u ve mentioned.
  11. D1559157572656 Cupcake Jun 12, 2019
    D1559157572656, Jun 12, 2019 :
    i downloaded it from oxygen updater app, its 100% safe and oroginal no root etc
  12. G_Marcin_Benko_YpgN Eclair Jun 12, 2019
    G_Marcin_Benko_YpgN, Jun 12, 2019 :
    Actually yes... You right...
    should I do anything with that?
  13. Rexisrex Gingerbread Jun 12, 2019
    mate are you familiar with BL unlock , custom recovery and root? bcos this is a patched version of the update and you'll need to root else you'll end up in boot loop. I don't have the device to test it and update as well. So if you're confident you can give it a try.
  14. DoctorDogEars Donut Jun 12, 2019
    DoctorDogEars, Jun 12, 2019 :
    Curious whether most people flashed or not? I was having a lot of problems and then did a local flash and all of my problems are gone now
  15. dubie7006 Eclair Jun 12, 2019
    dubie7006, Jun 12, 2019 :
    Hi all,
    Just want to get clarification/confirmation on something.
    Am I correct in saying the 9.5.6 (and subsequently 9.5.7) patch clears up the 'calls from Verizon iPhones' issue? I'm asking because I'm getting my OP7P tonight and want to get everything going as quickly as possible. So if I download 9.5.7 I should be good to roll?
    Also, despite downloading 9.5.7, I will still have to call Verizon (my carrier) and have them put my line to CDMA-less, right?
    TIA.
  16. Ksupernor2 Cupcake Jun 12, 2019
    Ksupernor2, Jun 12, 2019 :
    not really. my Samsung Galaxy S10 plus is on the May security patch already....
  17. Noneya Cupcake Jun 12, 2019
    Noneya, Jun 12, 2019 :
  18. KJGruca Cupcake Jun 12, 2019
    KJGruca, Jun 12, 2019 :
    If I have the T-Mobile 7 Pro, am I able to manually update to the most recent software from the OnePlus site? Or do I have to wait for T-Mobile to push out their update.
  19. barnabyj Gingerbread Jun 12, 2019
    KJGruca likes this.
  20. ac3of2pade2 Cupcake Jun 12, 2019
    ac3of2pade2, Jun 12, 2019 :
    you'd have to wait unless you flash the international version to your phone. it's what I did.
