180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. Khalid_Ismail_bafleh
    Cupcake Jun 19, 2019
  2. sime27
    Froyo Jun 19, 2019
    sime27 , Jun 19, 2019 :
    Just updated to 9.5.8 and using WhatsApp
  3. Swejuggalo
    Jelly Bean Jun 19, 2019
    Swejuggalo , Jun 19, 2019 :
    Maybe this is specific to WhatsApp then. Anyone that can verify? You could use the feedback tool and send a bug rapport.
  4. sime27
    Froyo Jun 19, 2019
    But your screen shot is WhatsApp
  5. Jatin8285
    Jatin8285 , Jun 19, 2019 :
    version is 8gb 256 GB . no root done in the phone..
    check your settings is button and gestures working properly if yes the. click on the navigations bar option which is back and home only that is second option. tell me after that is it working?? nd I am on 9.5.8 version
    see this setting backs nd home button is not working
  6. U1537697037219
    Donut Jun 19, 2019
  7. Steius
    Eclair Jun 19, 2019
    Steius , Jun 19, 2019 :
    GM1913 on 9.5.8 GM21BA
    Tested on Google Duo, Screen locked. The call arrive and i can start the videocall and then tap for popup camera.
    Tested on whastapp: same thing, phone ring from locked screen, i can answer and then pop up the camera or i can pop up camera and then answer. No problem with face unlock or other apps.
    For me i have better audio (calls, music and video).
    Italy update get yesterday with system upgrade.
    Hitman424 and Swejuggalo like this.
  8. Swejuggalo
    Tried all 3 navigation modes and I have no problem with any of them
  9. Lunatico
  10. Adtysrm
    Adtysrm , Jun 19, 2019 :
    It is the second day on OnePlus 7 Pro and my phone hanged. I have used Zen Mode and while using the Zen Mode, I clicked a few pictures. After 20minutes when the phone came back to normal mode, I have unlocked the phone. The finger print scanner says (finger print partially detected). I had to use the pin to unlock the screen. My navigation gestures weren't working. The phone was blank and some other accessibility options came at the bottom of the screen. And none of them were working. The only things working were alert slider, power button and lock screen pin for unlocking with more than a seconds' lag.
    I was terrified. Can somebody explain me what would have been the problem ?
    I am on 9.5.7!
  11. Lunatico
    Lunatico , Jun 19, 2019 :
    You don't know this since the update just got released!
  12. Hitman424
    Gingerbread Jun 19, 2019
    Hitman424 , Jun 19, 2019 :
    never again will i get phones from any carrier. they take forever with updates.
    Ultraman215 likes this.
  13. U1537697037219
    Donut Jun 19, 2019
  14. Jatin8285
    let me check because I am having the issue I think I have to reboot my phone
  15. Hitman424
    not sure but i havent used zen.. and i wont be. have you updated yet? get the oxygen os updater itts safe and quick to update.. also after every update go into recovery and clear the CACHE only.... and reboot
  16. sime27
    Froyo Jun 19, 2019
    Same
  17. Adtysrm
    I'll update anyhow, but some problem definitely exists with the phone. I can say that this is not a performance beast if something like is happening to me on the second day.
    I want to update with OTA.
  18. janfar
  19. W1560964617290
    W1560964617290 , Jun 19, 2019 :
    I'll be posting photo samples from my iPhone and OP 7 once my iPhone is back from repairs in a week. Hopefully all your mambo jumbo logic will still apply after that
  20. Swejuggalo
    You could always try to download the update with Oxygen Update if you have problems getting the update
    Hitman424 likes this.
