180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. Rahstyles
    Gingerbread Jun 19, 2019
  2. nateavi
    nateavi , Jun 19, 2019 :
    Great! Now focus on getting the wide angle and telephoto lens up to speed. They sure need more fine tuning.
    HardstylerDK likes this.
  3. paul67™
    S1558140694355 and Hitman424 like this.
  4. salvasad
    Froyo Jun 19, 2019
    salvasad , Jun 19, 2019 :
    is it only mee or is theere moore stuttering with some apps like youtube or twitter i have a fwaling rhis update is less smoother
  5. TheMysticalShaman
    Honeycomb Jun 19, 2019
  6. Demon_hunter
    Demon_hunter , Jun 19, 2019 :
    only you as of now
  7. Demon_hunter
    Honeycomb Jun 20, 2019
    Demon_hunter , Jun 20, 2019 :
    explain what do you mean by flagship quality feature lol
  8. mstella
    Froyo Jun 20, 2019
    mstella , Jun 20, 2019 :
    Anyone else experiencing the black color bleeding slightly when scrolling?
  9. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jun 20, 2019
    KeepTransisting , Jun 20, 2019 :
    Do you have DC Dimming enabled?
  10. mstella
    Froyo Jun 20, 2019
    I do. But it's still happening after turning it off.
  11. paul67™
    Gingerbread Jun 20, 2019
    paul67™ , Jun 20, 2019 :
    Firmware 9.5.8
    -Problems i experienced with gboard (poor response) are gone after this update. Maybe to do with the optimizing touch sensitivity for the screen as said....works great now :cool:
    -Audio quality is certainly improved; i can hear more detail and sound a bit clearer.
    -No issues with battery drain as some after the update.
    -No problems with camera as some after the update.
    Smoothly so far ;)
    Hitman424 likes this.
  12. salvasad
    Froyo Jun 20, 2019
    paul67™ likes this.
  13. G_Alex_ramos_JirP
    Cupcake Jun 20, 2019
    G_Alex_ramos_JirP , Jun 20, 2019 :
    u stupid. grow up.
    FRJerome likes this.
  14. paul67™
    salvasad likes this.
  15. salvasad
    Froyo Jun 20, 2019
    salvasad , Jun 20, 2019 :
    ty
    i left s10 plus for OP7 pro and i just love it every day
    TheMysticalShaman likes this.
  16. U1560042409660
    U1560042409660 , Jun 20, 2019 :
    what new update is coming out soon and what will it have ?? just curious ? will it be able to send a voice clip like Samsung and other phones do ??
  17. G_Gaetano_Zito_QOIU
    G_Gaetano_Zito_QOIU , Jun 20, 2019 :
    [QUOTE = "C3C0, post: 20451969, membro: 909018"] 1) Apri magisk, disattiva tutti i moduli attivi nel caso in cui ne usi e riavvia (solo per escludere i moduli che causano problemi all'avvio dopo l'aggiornamento del sistema)
    2) Utilizzare FULL ota zip (2 GB) per aggiornare ma NON RIAVVIARE ANCORA
    3) Aprire il magisk e fare clic su Installa e scegliere l'opzione "installa su slot inattivo (dopo ota)"
    4) Riavvia
    5) Quindi è possibile avviare l'abilitazione dei moduli magisk precedentemente disabilitati (se presenti)
    Ho aggiornato op7pro con root a 9.5.8 senza problemi. [/ QUOTE]
    Come scelgo lo slot vuoto? Non riesco a trovare l'opzione
  18. U1560042409660
  19. paul67™
    Inglese prego.
  20. janfar
