180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. janfar
    Cupcake Jun 20, 2019
    janfar , Jun 20, 2019 :
    change the device in updater.
    Top right hand corner of Updater- 3 dots>settings> set device to 7 pro
  2. Hitman424
    Gingerbread Jun 20, 2019
    Hitman424 , Jun 20, 2019 :
    go into recovery and clear your cache after any update. then Reboot
    also enter developer options... google it if u dont know how. once there change
    all 3 animations to 1x
    also make sure your screen refresh is on 90hz
    and under resolution make sure its not on auto switch... set it to QHD.....
  3. Bennettl87
    Eclair Jun 20, 2019
    Bennettl87 , Jun 20, 2019 :
    mattlucas
    how did you do this?​
    https://www.google.com/amp/s/www.xd...lus-7-pro-international-firmware-install/amp/
    Download the files, use an extracter app on your computer, put all files into one folder on your computer. Open the MSM file, uncheck the SHA 256 option. Then turn your phone off. Once it is off, press and hold the volume up and down button at same time for 5 seconds, then plug your phone into the computer. The MSM software will read Connected and then you press start. The one thing is, it will wipe your phone, so you will have to go back through the initial device setup process. Hope this helps.
  4. M1560539595814
    M1560539595814 , Jun 20, 2019 :
    How do you convert?
  5. TheMysticalShaman
    Honeycomb Jun 20, 2019
    TheMysticalShaman , Jun 20, 2019 :
    SwiftKey Keyboard is much better than GBoard
    U1546016258321 and Hitman424 like this.
  6. H1560074497143
    H1560074497143 , Jun 20, 2019 :
    Please refer the suggestion for firmware upgrade ASAP as following:
    1. please add: Left and right slide function for return menu .
    2. Please add :simply settings and multiple modes to the camera menu, for example, add ultra-macro distance, text mode, etc.
    3. Please add : the page display mode of apps icon for sort out , as well as multiple modes to add apps arrangement.
    4. Please add a variety of pre-camera sound effects, as well as finger unlock display effect.
    5. Optimize the game effect and compatibility issues under 90hz.
    6. Please add : battery pool optimization and view the percentage of battery capacity consumption, kernel optimization, garbage storage and cleanup options.
  7. elanglois
    Lollipop Jun 20, 2019
    elanglois , Jun 20, 2019 :
    Sounds like an app you have installed. It's ALWAYS an app. If the issues persist reboot to safe mode. If this works, start removing things you can do without
  8. elanglois
    Wow. Please stop.
    Do NOT clear caches! This will make the problems the person is experiencing WORSE
    Do NOT go into developer options. If you are not a developer and capable of writing software, stay out! That menu is hidden and requires your password for a reason.
    A lower screen refresh would actually make the phone's battery last longer. Setting to 90Hz is for aesthetics
    Resolution SHOULD be set to auto-switch for best compatibility. No reason to force QHD. And again, you'll get better battery life at lower resolutions.
    royalemint and Hitman424 like this.
  9. elanglois
    Yes. Stop setting it in developer settings. Its supposed to negotiate the best settings automatically
  10. elanglois
    Never seen that
  11. elanglois
    Download the full 2GB ZIP with your browser and install using the Local Upgrade feature
    Hitman424 likes this.
  12. P1558451629391
    P1558451629391 , Jun 20, 2019 :
    when i was playing game and call come when i pick up call the screen become black for some second and lag the phone .and after 2-3 second phone become normal. and some time the rear camara is choppy on first 3-4 seconds.
    please fast slove this problem
    regod likes this.
  13. paul67™
    paul67™ , Jun 20, 2019 :
    Set it to 0.5 all 3. ;)
    kevinplus2 and Hitman424 like this.
  14. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jun 20, 2019
    KeepTransisting , Jun 20, 2019 :
    Stop recommending people clear cache. This is a useless procedure these days.
    royalemint and elanglois like this.
  15. T1560999848721
    T1560999848721 , Jun 20, 2019 :
    my OnePlus 7 pro is always stuck whenever I open the play Store and download any app they show downloading and stuck their
  16. D0310
    Donut Jun 20, 2019
  17. KeepTransisting
  18. C3C0
    Froyo Jun 20, 2019
    C3C0 , Jun 20, 2019 :
    That's cool but you never know what kind of modules others run. Modules can suddenly become incompatible with changes new update brings. I've seen people bootlooping in the past because of this .
  19. Hitman424
    ok thanks for the heads up... i know ur right it does take a toll on battery
  20. elanglois
    The only thing that comes to mind is things like ICE that are modifications of OOS files and would be specific to a certain version of OOS. Shouldn't turn it on after reboot either.
