180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. U1560878990749 Cupcake Jun 20, 2019
    U1560878990749, Jun 20, 2019 :
    Hi,
    I've been having an issue these past 24 hours where my lock screen when turned on would flash my wallpaper briefly, go dark and then display my lock screen.
    It's been perfectly fine up until this. Has this happened to anyone else. Has this been reported before as I haven't seen anything on it yet or does anyone have a solution to it?
    I haven't upgraded to the latest version or OOS yet as I'm in the UK and it hasn't rolled out here yet but I can't find anything in the patch mentioning this so not sure if an update would fix this issue.
    Is this the best way to reach the OnePlus team or would I be better off contacting them in another way?
    Thanks.
    regod likes this.
  2. nevin_john Donut Jun 20, 2019
    nevin_john, Jun 20, 2019 :
    Found out that the camera won't pop up when the screen is off. However, it still pop-ups if the screen is on.
    IMHO, it shouldn't pop up under any circumstances and should ask the user before popping up. I hope they look into it!
    gmaria1987 likes this.
  3. alttafv Eclair Jun 20, 2019
  4. alttafv Eclair Jun 20, 2019
    alttafv, Jun 20, 2019 :
    Do you mean this one? But my OEM is locked. And I'm scared if i unlock OEM, my device will be factory reset or get stucked on reboot.
  5. Swejuggalo Jelly Bean Jun 20, 2019
    Swejuggalo, Jun 20, 2019 :
    No no... The advanced mode is in Oxygen Updater. Blue marked it.
    alttafv likes this.
  6. alttafv Eclair Jun 20, 2019
  7. salvasad Froyo Jun 20, 2019
    salvasad, Jun 20, 2019 :
    ty fot the help [e]1f44d[/e]
  8. Swejuggalo Jelly Bean Jun 20, 2019
    Open the app Oxygen Updater.
    Step 1
    Step 2
    Go back and you should have a option to download the full update
    Hitman424, alttafv and salvasad like this.
  9. alttafv Eclair Jun 20, 2019
  10. Swejuggalo Jelly Bean Jun 20, 2019
    The cog up at the right corner.
    Local upgrade.
    Select the downloaded file.
    Hitman424 and alttafv like this.
  11. alttafv Eclair Jun 20, 2019
  12. Ultraman215 Gingerbread Jun 20, 2019
    Ultraman215, Jun 20, 2019 :
    I agree with you. The selfie camera should only pop up when:
    1) You initiate selfie mode in the camera
    2) You initiate a video call
    3) You answer a video call
    4) You enable face lock and are attempting to initiate an unlock of the phone.
    Am I missing any other logical use case?
  13. alttafv Eclair Jun 20, 2019
    Swejuggalo likes this.
  14. alttafv Eclair Jun 20, 2019
    Hello
    Can anyone tell me what is benifit of Force GPU rendering in developer option?
  15. Swejuggalo Jelly Bean Jun 20, 2019
  16. J1559419748557 Cupcake Jun 20, 2019
  17. Karl_Columna Eclair Jun 20, 2019
    Karl_Columna, Jun 20, 2019 :
    use Oxygen Updater
  18. Swejuggalo Jelly Bean Jun 20, 2019
    You could update with Oxygen Updater or use a VPN and connect to Germany or Hongkong depending on what version you have. Reopen the updater again after connecting and you should see the update soon.
  19. jeremyhass Gingerbread Jun 20, 2019
    jeremyhass, Jun 20, 2019 :
    my bluetooth is broken now, worked fine on 9.5.7, factory reset and everything and will not pair with my bluetooth speaker like it did in 9.5.7, so I guess I will have to downgrade.
  20. Swejuggalo Jelly Bean Jun 20, 2019
    That function forces all apps to use it even if they are not made for it. The possible gain vs possible issues can be hard to know. More and more apps use it by default already.
    alttafv likes this.
