180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. T_A_R_A_S
    Froyo Jun 20, 2019
    T_A_R_A_S , Jun 20, 2019 :
    Here I am about the same, it would be great
  2. T_A_R_A_S
    Froyo Jun 20, 2019
    fine
  3. K1560670394776
    Donut Jun 20, 2019
    K1560670394776 , Jun 20, 2019 :
    voice over LTE (4G) voice calling. quality is much higher why would you turn it off?
    apat26 likes this.
  4. Hari_Dwivedi
    Gingerbread Jun 20, 2019
    Hari_Dwivedi , Jun 20, 2019 :
    Back to back 2 updates for Pro and nothing is available for the regular one 7?... is this something which is missed from the OnePlus development team or they just want us to keep shouting like this coz we have not paid a premium amount as the Pro user paid to the brand...
    I understand it might sound slightly negative to the Pro users specially who are not interested to listen against to brand but it is really annoying whenever and wherever such partiality happen.
  5. rockinrobin
    Cupcake Jun 20, 2019
  6. samrat ghosh
  7. Swejuggalo
    Jelly Bean Jun 20, 2019
    Swejuggalo , Jun 20, 2019 :
    9.5.5 was released not that long ago. I'm sure they add more soon. Especially when some users have experienced better flow and less lag with their older 6T... I bet it will beat 6T every day eventually when the software gets tweaked and fixed a bit more.
    Even the Pro 5G version gets slower updates than the 4G version.
    3 new devices at one time might cause some of the turbulence with the updates. But I guess it will calm down eventually and focus will be more evened out between the devices.
  8. Swejuggalo
    You could use Oxygen Updater app to download the update or use a VPN and connect to Hongkong. After connecting go into settings again and check for updates.
    samrat ghosh likes this.
  9. samrat ghosh
    samrat ghosh , Jun 20, 2019 :
    is it safe?
  10. surajit20
  11. jimboctration
    Eclair Jun 20, 2019
    jimboctration , Jun 20, 2019 :
    does the 9.5.7 update increase picture sharpness. I don't have it on the 5g version but it's the only problem I have with the phone
  12. Swejuggalo
    Yes.
    In my case it looks like this in "my device"
    In your case it should only say Oneplus 7 Pro with GM21AA software instead of GM21BA is in my case.
    In settings it should automatically be set it to regular global Oneplus 7 Pro. The app also gives info about how to update.
  13. Swejuggalo
    Yes that version got the improved camera. Hopefully next 5G update will have it too.
  14. C1556827425967
    Donut Jun 20, 2019
    C1556827425967 , Jun 20, 2019 :
    last update fixed camera drastically. i no longer have noise in pictures , brightness has been fixed focus and low light pictures are awesome. I don't use gcam no longer now.
  15. samrat ghosh
    thanks..i have started downloading the firmware
  16. Hari_Dwivedi
    Well said..but it is still running very slow as compare to the 7Pro in terms of making worth to the newly introduced devices. Brand has not done well in terms of keeping the promised at the time of launch event and the actual user experience of the just launched devices.
    But thankfully they have started to add actual value into it by pushing updates.. very much appreciated at this moment.
    But,.. on the other hand brand is also creating two separate spaces for same series of devices 7 and 7 Pro..which is very much annoying here.
    Hope OnePlus will acknowledge this and make all the OnePlus users happy.. or I would say ..giving expected value of their money atleast.
  17. jimboctration
    Eclair Jun 20, 2019
    can the 9.5.7 update be applied to the 5g phone. I know it would probably disable 5g but is it possible
  18. samrat ghosh
  19. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jun 20, 2019
