180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. J_Alarcon
    Cupcake Jun 21, 2019
    J_Alarcon , Jun 21, 2019 :
    OnePlus has a separate 5G version of the 7pro for a bit more money (not sure of price ).. if you didn't buy the 5G version it is not going to "convert". Most companies here (in the US) like At&t are "updating" their Network to say 5Ge (5G evolution)but it's not running on a 5G network. you'll need a 5g phone to run a 5g network. hope this is helpful!
  2. Daasty
    Honeycomb Jun 21, 2019
    Daasty , Jun 21, 2019 :
    Tunnerbear worked fine. Anyways, you can try orbot, a Thor browser. Should work better than the other options.
    chester4400 likes this.
  3. J_Alarcon
    KeepTransisting likes this.
  4. rockinrobin
    rockinrobin , Jun 21, 2019 :
    very. thanks! I guess by the time 5G really rolls out,it will be time to upgrade anyways.
    is 4G going to eventually become obsolete?
  5. Bennettl87
    Eclair Jun 21, 2019
    Bennettl87 , Jun 21, 2019 :
    https://www.google.com/amp/s/www.xd...lus-7-pro-international-firmware-install/amp/
    Download the files, use an extracter app on your computer, put all files into one folder on your computer. Open the MSM file, uncheck the SHA 256 option. Then turn your phone off. Once it is off, press and hold the volume up and down button at same time for 5 seconds, then plug your phone into the computer. The MSM software will read Connected and then you press start. The one thing is, it will wipe your phone, so you will have to go back through the initial device setup process. Hope this helps.
    Ultraman215 likes this.
  6. gmaria1987
    Froyo Jun 21, 2019
    gmaria1987 , Jun 21, 2019 :
    My thoughts on this update. Great update! Used the camera for the raptors parade for video and I must say I was impressed with the color saturation and the stabilization of the camera! Looking forward for the wide angle video! I loved that you guys put an option to raise the camera for video conferencing apps like whatsapp... But the camera still pops up while the phone is turned on. You guys should add that option at least within the system settings to have it enabled or disabled.
  7. H1542153384332
    Gingerbread Jun 21, 2019
    Montpbm and pvitale like this.
  8. H1542153384332
    H1542153384332 , Jun 21, 2019 :
    within a week or so TMO will release the latest version. why waste time and end up with a wiped phone and spend time reinstalling all your apps then moving your apps around.
    Montpbm, Hitman424 and pvitale like this.
  9. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jun 21, 2019
    KeepTransisting , Jun 21, 2019 :
    because the global version will always get software faster without the TMobile garbage installed with it
    Montpbm likes this.
  10. A1559419311796
  11. H1542153384332
    4G LTE Will be around for a long long time.
    Hitman424 and rockinrobin like this.
  12. amit2798
    Donut Jun 21, 2019
  13. amit2798
    Donut Jun 21, 2019
    amit2798 , Jun 21, 2019 :
    Pls update msg application little bit changes required like stop msg sending in 10 sec, sending msg style change so on.
  14. amit2798
    Donut Jun 21, 2019
    One more problem I am facing is the battery problem. If we work on 60 hz the battery is still not running full day. Pls try to improve the battery backup in both 60 hz and 90 hz display at whole day in normal use
  15. H1542153384332
    Right now you'll need to reset the phone. it works for me to use Google assistant.
  16. KeepTransisting
    Random question, do you have an app called Plus Beat installed?
  17. JeremyGriffiths
    Eclair Jun 21, 2019
  18. A1971
    Eclair Jun 21, 2019
    A1971 , Jun 21, 2019 :
    I wish there was a way to force the 90Hz everywhere, all the time, all apps, no exception, without
    having to do that ADB maneuver!
  19. 22hemant
  20. Forzaroma1927
    Forzaroma1927 , Jun 21, 2019 :
    Con vpn turbo metti come paese la Germania e poi vai su aggiorna sistema te lo scarica via ota subito
