180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. HZ_ND
    Gingerbread Jun 23, 2019
    HZ_ND , Jun 23, 2019 :
    Yes u will get the camera update together.. Don't worry.njoy the beauty of oneplus.
  2. kanagaraj1010
    Ice Cream Sandwich Jun 23, 2019
    kanagaraj1010 , Jun 23, 2019 :
    s u got it
  3. D1559517744009
    Cupcake Jun 23, 2019
  4. ButterFlYnez
    Jelly Bean Jun 24, 2019
    ButterFlYnez , Jun 24, 2019 :
    First bug ever on a oneplus device: starting game mode crashes my user interface. I have to input my pin and the device says it needs pin after a reboot. Not really sure why though... It only happened after getting the Ota for 9.5.8 BA (yes I have European device).
    regod likes this.
  5. Sreekanth Sree
    Cupcake Jun 24, 2019
    Sreekanth Sree , Jun 24, 2019 :
    yes...I do accept after 9.5.8 battery consumption is increased compare to before and facing in display finger print issue (it's showing not recognized) and face unlock issue ( am using power button to unlock display but it's atomaicly opening just by using (power button + swiping) swiping without showing pin number .this is a major issue security I I have brought to your notice last time also but I didn't get the resolution to that after 9.5.8 update very bad...
    please provide stable updates to reduce the issues but now after 9.5.8 again making battery consumption and in display finger print issue which not use to have with my device...we have average battery life for 7pro please try to increase that with update. and also I would request to you guys to manufacture a back case with additional battery where in travel it we can carry for additional juice instead of using normal power banks which will not do fast charge to one plus devices....
  6. U1561301574175
  7. Abhay Gaikwad
    Froyo Jun 24, 2019
    Abhay Gaikwad , Jun 24, 2019 :
    yeah , i am facing same issue. I finally give up on oneplus team. each update was suppsoed to make phone work better.
  8. U1561301574175
    U1561301574175 , Jun 24, 2019 :
    Agreed. 9.5.7 Was perfect. I updated 9.5.8 Yesterday and it ruined my trip's video.
  9. Abhay Gaikwad
    Froyo Jun 24, 2019
    i noticed battery consumption is also increased. Do they even read this forum ? i am curious about that.
    HZ_ND likes this.
  10. AngieValadez
    Donut Jun 24, 2019
  11. HZ_ND
    Gingerbread Jun 24, 2019
    HZ_ND , Jun 24, 2019 :
    There is some increased in battery consumption with the newer software. Had the previous apps and same usage. But a bit increased in battery consumption.the video stabilization need some fixing at 1080 60fps..i think only certain phones having this issue..y friends phone is working fine with the latest update.Anyhow I trust in oneplus team to sort this out fast
    Cheers... Thank you for listening to us and improving the user experience.
  12. D1558816333180
  13. Dbozeman81
    AngieValadez likes this.
  14. Abhay Gaikwad
    Froyo Jun 24, 2019
    @Manu J.
    is there anyway i can rollback to 9.5.7 without any boot failure ?
    9.5.8 is clearly not fine for me. battery is going down fast without using my phone i m getting .
    In camera portrait mode is not working correctly , blurr is too agressive and edge detection is very bad it , overall photo looks bad.
    why do you have to make things bad ? i was happy for security patch update but these things are annoying.
    ButterFlYnez likes this.
  15. amansinghiam
    Eclair Jun 24, 2019
    amansinghiam , Jun 24, 2019 :
    thats beacuse your screen was on. try calling urself from another number when your screen if off.
  16. rahulnair1607
    rahulnair1607 , Jun 24, 2019 :
    you could have included a sound when phone is kept on charge. like different sounds when dash warp or simple charge. just an opinion
    HZ_ND likes this.
  17. HZ_ND
  18. gtawfikpe
    gtawfikpe , Jun 24, 2019 :
    after the new update the phone doesn't connect with my Lexus RX media so I can't control media player on the phone from my car
  19. I1559228802632
  20. rclotz
    Honeycomb Jun 24, 2019
    rclotz , Jun 24, 2019 :
    Guys, I don't know what you are doing with your phones.
    I don't have any of the issues you described in the latest posts and my phone is perfect.
    The 9.5.8 update did nothing for the camera. Please read the update notes of Oneplus.
    So it is impossible that the camera is worse after that.
    Also check other threads in the forum where are examples of the great quality of the camera.
    The battery life is great. Usually about 9 hours SOT before I have to charge.
    So I am really satisfied and for me the Oneplus 7 phone is the best I ever had.
    FRJerome and Abhay Gaikwad like this.
