180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. HZ_ND
    Gingerbread Jun 24, 2019
    HZ_ND , Jun 24, 2019 :
    I think only certain not all phone are affected.
    Rest assured all updates gives a great performance.
    rclotz likes this.
  2. Abhay Gaikwad
    Froyo Jun 24, 2019
    Abhay Gaikwad , Jun 24, 2019 :
    yeah it sucks for me , cuz i am having issues.
    HZ_ND likes this.
  3. HZ_ND
    Same. Here.. But some of my friends using the same updates not having and issues.. And some does... Dint think so it's regional problem.. But they will find a fix for it.
  4. K1542592141528
    Cupcake Jun 24, 2019
    K1542592141528 , Jun 24, 2019 :
    I got the update this morning, with one exception it works fine. I am on the T-Mobile network and the update shut off my Cellular data connection after a reboot. On the plus side, after calling customer service and learning this I discovered that the nearest tower is begining the upgrade with 5G equipment. So lesson here, check your Cellular data after update.
  5. kanagaraj1010
    Ice Cream Sandwich Jun 24, 2019
    kanagaraj1010 , Jun 24, 2019 :
    same issue here also after the update one plus team fix this issue in coming updates
  6. Abhay Gaikwad
    Froyo Jun 24, 2019
    are you also having issue with portrait mode ? blurr is too much and edge detection is also not proper. 9.5.7 was good and even 9.5.8 did not mention anything about portrait mode i am facing this after this update because i know i shot way too many portrait images.
  7. K1542592141528
  8. baggz143
    baggz143 , Jun 24, 2019 :
    9.5.8 is full of issues. app freezing. Battery consuming a lot. major Bluetooth issues with absolute volume not working properly. sometimes it connects to car but doesn't play music but everything else works. have to reconnect Bluetooth twice before it finally wants to play music .
    that's just some of them.
    and yes Camera neeeeeeeds more development.
    regod, Marek_Orovnicky and HZ_ND like this.
  9. HZ_ND
    Have u try reseting ur device setting.. Clean ur system.
    Mine is very well balanced. No issues
    FRJerome likes this.
  10. HZ_ND
    Might depends what car player u r using.. I'm currently using Sony xav 712 bt.. The Bluetooth working well and the volume buttons no hiccups.. Tried using other Bluetooth device like my Logitech speaker. And it did perform well too
    baggz143 likes this.
  11. kanagaraj1010
    after the update while I plug into charge there is no sound any one facing this issue please check and tell me.
  12. Abhay Gaikwad
    Froyo Jun 24, 2019
    Take a photo of your friend or yourself and watch. i am not asking to post it here but you can clearly see the difference. i've clicked hundreds of them before 9.5.8 and the change js easily noticable .
  13. Zeljko777
  14. HZ_ND
    I'll do some clicks and let u know
  15. Abhay Gaikwad
    Froyo Jun 24, 2019
    HZ_ND likes this.
  16. HZ_ND
    Yes having the issues with portrait mode.edge detection a bit false and too much blurring of surrounding area.
  17. Abhay Gaikwad
    Froyo Jun 24, 2019
    Yeah man, facing the same issue. i hope they will fix this with update. i dont know why they did this lol.
  18. HZ_ND
    Something must been added to the camera I thing.
    Altought it's not stated.but it's ok.. Wait for the another rupdate.
    Will. Keep on coming bro..
    Abhay Gaikwad likes this.
  19. kanagaraj1010
    while plug in to charge any sound is appearing r not appearing can u help me
  20. Abhay Gaikwad
    Froyo Jun 24, 2019
    I didnt get any sucj sound since i got my device (20may) and in latest FAQ section you can see they are gonna add charging sound in next update (hopefully).
    HZ_ND likes this.
