180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. baggz143
    Gingerbread Jun 24, 2019
    baggz143 , Jun 24, 2019 :
    The issues is not only connectivity but absolute volume is not going all the way up to max on phone which it did before the update. that's a major for me me personally.
  2. R_d_M
    Froyo Jun 24, 2019
    R_d_M , Jun 24, 2019 :
    is it possible to downgrade to 9.5.7 without root ?
    i'm really thinking about it, but it's my first oneplus device and online i find different answers to this question...
    if anyone could help me out...
  3. Sachin100
    Donut Jun 24, 2019
  4. salvasad
    Froyo Jun 24, 2019
    salvasad , Jun 24, 2019 :
    thinking the same but dont know how [e]1f609[/e]
  5. FRJerome
    Ice Cream Sandwich Jun 24, 2019
    FRJerome , Jun 24, 2019 :
    You mean selfie ?
    Or portrait mode ?
    Face correction on ? Off ?
  6. FRJerome
  7. Sachin100
    Donut Jun 24, 2019
    Sachin100 , Jun 24, 2019 :
    2hours 30 mins
  8. alttafv
    Eclair Jun 24, 2019
    alttafv , Jun 24, 2019 :
    Hello
    Pls help me to remove camera and call button from lockscreen. It was easier for me to remove on Samsung and Xiaomi phones. But i can't find it here.
  9. FRJerome
  10. I1561338723757
    Cupcake Jun 24, 2019
  11. Aathif_Mahir
  12. alexbukowski89
    alexbukowski89 , Jun 24, 2019 :
    Can a pop-up notice be added when the update is ready and wanting to install, similar to Samsung or Apple devices? My 7 Pro restarted itself while I was holding it and reading something. No notice, just interruption.
  13. apat26
    Froyo Jun 24, 2019
    apat26 , Jun 24, 2019 :
    Both are with May security patches. For an upgrade, you need to have a higher security patch.
    Another option is to upgrade to Android Q dp version and then you can downgrade back to lower version and then come to OOS.
    Rise wait for the next update version with higher security patch.
  14. R1561381831898
  15. apat26
    Froyo Jun 24, 2019
    As said above, upgrade to DP Android Q and then downgrade back to P which is a lower version. Then you can upgrade to 9.5.7
    But be careful as Q is with a lot of issues.
  16. Ezekiellachevre
    Ezekiellachevre , Jun 24, 2019 :
    Could you improve the camera sharpness so that my pictures actually shoot in 48megapixels and so that I can zoom into a picture and not see it blurred or look like a painting. all my pictures are not sharp enough and end up blurred please fix.
    baggz143 likes this.
  17. Abhay Gaikwad
    Froyo Jun 24, 2019
    Abhay Gaikwad , Jun 24, 2019 :
    I didnt whine because of overall blurry photos .Read carefully what i typed there again and no one mentioned capturing portraits in low light so your answer does not help anyone.
  18. IwantOneplus!
    IwantOneplus! , Jun 24, 2019 :
    how do you figure out what's waking your screen? my phone is randomly waking. I don't want to do rooting
  19. Ezekiellachevre
    u can check your lock screen settings to see if you have raise to wake active. turning it off could help I guess. If that doesn't work try restart your phone.
  20. IwantOneplus!
    I have it on but I'm not picking my phone up.
